586,983 active members*
3,673 visitors online*
Results 1 to 11 of 11
    Mar 2008
    15
    What can i cut with my laser ( 40w co2 )
    Ive been trying allsorts of things but im just wondering if there is a list, or if people can post what mterials i can cut!
    So far i have done (with no problems)... balsa, ply, perspex, ABS, cardbord, obechi veneer and a few other bits and pieces
    With limited success .....Depron, eva foam, foamboard, corex, StarSpan tissue paper ( the cloth type tissue )
    The list to try....can it be done, can i cut or engrave thin sheets of the following ( i dont have any to test!) ?
    GRP, Carbon fiber sheet, Kevlar, Paxolin,bakelite, rubber, silicone rubber, glass , marble , slate, granite, nylon, silicone/mica gasket material ?
    I tried to engrave on an amber glass pharmecutical bottle and it just exploded into bits as soon as the laser was on the bottle?
    To colour aluminium, can i remove annodising with a co2 laser of 40w? to leave coloured parts, or will it just look bad?
    Feb 2009
    11
    Engraving Glass
    Some people have tried engraving glass by covering the area to engrave with a moist but not dripping wet paper towel.
    Ken
    Sep 2007
    28
    GLASS
    Thats used if ur tring to engrave a mirror glass surface to stop the reflecting (I havent tried it and if a mistake is done it could cost u new lens i think )
    Normal glass doesnt require a wet towel
    Shadow
    Dec 2008
    1258
    Quote Originally Posted by StarLoc View Post
    I've tried some of the above, here are my results...
    Carbon fiber sheet = Would not cut - it melts and smells bad
    Bakelite = Engraves well
    Rubber = Thin sheets cut well, and can be engraved to produce stamps
    Silicone Rubber = same as above
    Glass = Engraves easily
    Marble = Varies - but usually engraves enough to fill
    Slate = Engraves well
    Granite = Engraves well
    Nylon = It will cut but not very clean
    Gasket materials = same as rubber, works well
    Anodized Aluminum = very easy to engrave
    Hope this helps. I'm not sure why the amber glass fractured, perhaps it had a flaw or you used too much power. If you use a wet paper towel or just soap/water on the surface it will help prevent excess heat.
    Zax.
    Sep 2007
    28
    AMBER GLASS
    You will prob find the reason the amber glass fractured on contact is that it will be lead based
    You cant engrave lead crystal either without the same problem
    When the laser hits the glass it heats any metal within the product very quickly cause it to shatter so i dont think the wet towel will do anything for u either as it the metal in the glass heating up
    Shadow
    :rainfro:
    Oct 2007
    240
    Quote Originally Posted by SHADOW042 View Post
    :nono: I have no problems etching leaded glass. In this case I'm willing to bet there was simply a major flaw in the glass, and the laser heated it up until it gave way.
    Hi-TecDesigns.com -- Automotive Lighting Systems
    Jul 2009
    What do you use Starloc?
    Starloc, I would be interested in what your set up is that cuts balsa?
    Can you give me any leads?
    Thanking you
    Kvar
    Dec 2008
    1258
    Kvar,
    Balsa is easy to cut (up to 1/4", I haven't tried thicker), the edge will have a slight amber to brown discoloration.
    I have also found basswood to be excellent, slightly heavier but produces a nice clean cut and not much scorching.
    Zax.
    Apr 2012
    12
    this is cheaper laser machine. hope can help you.
    40 watt co2 laser machine cnc router without laser tube engraver cutter
    Mainly used for engraving of non-metal materials: such as Rubber / Ox horns / Wood / Plexiglass / Atomic materials / Crystal / Bowlder / etc...
    This is a 3 year old thread and the chap concerned has been using his laser very successfully since posting.
    Dragging up old posts just for the sake of advertising is bad practice and will put people off your machines!!
    not to mention thats a K40 which is crap when its brand new let alone 4 years old.
    Nov 2012
    96
    Hey, go easy on the guy. How many other laser vendors sell machines that can engrave "Atomic materials"?
  1. Questions for you laser guys - building own laser control
    By Sputnik in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-03-2015, 04:30 PM
  2. Add US made laser module to Chinese laser?
    By glintid in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-02-2012, 08:43 AM
  3. CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!!
    By oliver9866 in forum Engraving Machines
    Last Post: 12-15-2010, 09:44 PM
  4. Replies: 0
    Last Post: 10-17-2008, 04:17 PM
  5. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-13-2007, 08:39 PM
