Hi guys, I am new here as I just bought a Minitech Minimill/2. Serial number 10206. I'm guessing this machine is over 20 years old, but is in excallent condition! Of course it still has the old controller and the 150oz. round Slo/syn steppers. I am a patent attorney, not a cnc expert... so here I go with my questions:
I plan on making items out of aluminum for a hobby. Are these steppers even close to being large enough to do this? Keep in mind that I do not particularly care if I have to take small cuts at the workpiece. Would I be better to throw the controllers and steppers in the trash and purchase a new controller and steppers? If so, which ones to buy? From what I have read, the Gecko 540 seems to be pretty good. Are there any steppers that will bolt right on?
[150 oz-in isn't the most powerful stepper motor in the world, but if this setup is working for you now, see what it can do before scrapping it. The oz-in figure is holding torque at standstill, but there are other figures that are relevant as well, like inductance (lower inductance means the motor is more responsive) and the speed/torque curve (stepper motors lose torque as they accellerate faster).
Get some aluminum, fasten it to the bed, and try cutting it. To start with, you can give it simple G-code commands like G01X5.0F5. (If you're at X=0, this tells the machine to go 5 units in the x-positive direction, at a speed of 5 inches per minute.) Check to see if it really went that far. If it all looks good, position your tool (this would usually be an endmill) so that will cut on the side of your piece of aluminum (which is easier than plunging into the middle), turn on the spindle, and give it a command like the one above. See if it does as well when actually cutting as it did in air. If it fails to do that, then you're probably pushing it too hard - either take a lighter cut, or reduce the speed. You should be able to figure out pretty quickly what your machine is capable of, and what will make it lose steps, which is something you want to avoid.]
2. What other kind of software do I need? I'm guessing a good CAD software package and a complementary CAM package. I have seen that a lot of people here use Meshcam for the CAD portion. What are most of you using? Also, I have researched many different kinds of CAD software but quite frankly I am overwhelmed and don't really understand what I need. And ideas? I am not Bill Gates, so I have to keep a dollar limit for my new hobby.
[There's a lot of different CAD and CAM software in the world, ranging in price from free to tens of thousands of dollars. It's easy to get overwhelmed. (Meshcam, by the way, is CAM, not CAD). CAD software defines your part in 2d or 3d, depending on the program; CAM software turns it into a toolpath your mill can execute. If your mind works best in 2d, you can start with programs that are limited to that, and work up to 3d. Or you can take the plunge and start with a 3d program, which generally will have 2d capabilities as well. If you're penniless and eager to learn, you can start by trying all the free programs you can find until you click with one of them. If you have a harder time learning things, some money, and limited time, it's best to identify a program that will do everything you're likely to want, and dig in.
If your time is worth anything, the major investment you'll be making is the time that it takes to learn to use the program, which will typically stretch into hundreds of hours. So it's a false economy to purchase an inferior program just because it's cheap, wasting a lot of time learning something that ultimately won't do what you need. Look for well-regarded programs that offer free demos, so you can see if you get along with them before plunking down your cash. Here are a couple: Rhino (
www.rhino3d.com) will work for 25 saves before it times out. It's a 3d CAD program with a lot of functions for all sorts of applications from 2d drawing to compound-curved 3d surfaces. DeskProto (
www.deskproto.com) is a 3d CAM program with support for a rotary 4th axis, with a simple interface but enough power to handle large and complex files. The demo you can download from their site will last for 30 days, and will produce G-code files you can try out on your machine.]
3. Are there any books I can read to come up tp speed? I have to tell you that this all seems like magic to me. Is the learning curve so steep that I need to get some formal training?
[It's a lot like magic, but I haven't seen a book that has all the spells and potions. You're better off reading manuals for specific programs and machines than trying to find one source for everything. There is certainly a learning curve, but the formal training I've seen tends to focus on certain very expensive programs used in industry (schools get them a lot cheaper), rather than the consumer-level ones mere mortals can afford.]
Thanks in advance guys. I'd gladly swap some patent advice for some CNC advice!
Best regards,
Tony
