586,773 active members*
9,319 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > harbor freight 7x10,fuse blown,not working
    Jun 2009
    10
    Hey guys, I'm new to this forum, and to lathing in general. I purchased a 7x10 mini lathe from harbor freight. Well after milling, and stopping the spin by going too deep with a cut, the motor stopped. popped a fuse. luckily there was a spare, but even with that it will not work? It clicks. If is move the clear cover that hangs over the chuck I hear a relay click.
    Any info on how to make this work, if did I damage something??
    If I did, where can I send it to?
    Thanks in advance.
    -FPM
    Jun 2009
    10
    wow. some how I kept missing with that bar that holds the plastic cover and it worked!
    -Fpm:banana:
    May 2009
    141
    I did the same thing when I first bought my lathe! I didn't put the chuck cover on and the machine wouldn't work. I almost brought it back to the store, but finally found the safety switch.
    Glad to hear you found the problem!
    Dale P.
  1. fanuc spindle fuse on dc link blown
    By Nastyzen in forum Fanuc
    Last Post: 02-02-2023, 05:25 PM
  2. Replies: 20
    Last Post: 05-27-2009, 04:29 AM
  3. Fanuc Power Supply Internal Fuse Blown
    By hrhoward in forum Fanuc
    Last Post: 01-07-2009, 10:42 PM
  4. 0.6 amp fuse blown
    By highspeedmazak in forum Tormach Personal CNC Mill
    Last Post: 09-05-2008, 05:11 PM
  5. harbor freight X2 is now $579?
    By isaac338 in forum Benchtop Machines
    Last Post: 05-13-2008, 12:09 PM
