Greetings group.
When I goto to "Graphics Simulation" mode and I want to zoom in with F2, I get the error message, "NO ZOOM IN 3D". What the? I've used this feature before and it worked fine. What am I doing wrong?
JD
Greetings group.
JD
Dean,
Setting #3 in the setting pages, is "3D graphics" on or off..need to change it to Off..as far as I know it will not zoom in 3d...hence the error message..
HTH
WMS,
That worked! I don't know how that setting got tweaked, I must have misfired while crusing around looking for a solution.
Thank you!
JD
you have to go to the setting that says 3d graphic turn this function off or on one or the other then it will work . you must of gave it the code to turn this off
Looks like that was resolved almost 3 years ago.
