586,555 active members*
3,357 visitors online*
    Jul 2003
    126
    Spring Loaded Rack and Pinion request
    Working on my plasma table. Have the cross slide done.
    Working on the long axis. Using rack and pinion setup. So far I have the motor mounted with a belt going to a driveshaft which runs to each side to another pulley. I now need to connect that pulley to the pinion. Rack is mounted upside down (teeth facing the floor).
    Anybody have any good drawings, or suggestions on how to connect it?
    Want to make it spring loaded, and though of an arm that pivots at the driveshaft end, being pulled up onto the rack. Not sure it is going to be stable enough though.
    Hopefully figure something out tomorrow, so any suggestions soon will be appreciated.
    24223
    This is how I have done it in the past with a Rosta Tensioner, This pivots the motor assy and provides tension into the rack http://cnczone.com/forums/showthread...ighlight=rosta
    Also some I have seen some Tables that has used a Gas filled shock for tension.
    Al
  1. Linear Motion FAQ
    By Cutters Cove in forum DIY CNC Router Table Machines
    Last Post: 03-08-2018, 02:14 AM
  2. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  3. Direct drive with stepper on rack and pinion.
    By jerryrigge in forum Linear and Rotary Motion
    Last Post: 10-10-2007, 03:21 AM
  4. Rack & pinion
    By coolman in forum DIY CNC Router Table Machines
    Last Post: 05-07-2006, 10:14 PM
  5. Rack & pinion
    Last Post: 11-30-2004, 05:57 PM
