I am starting a project using an old Roland GRX 400 plotter from a flea market. The plotter was built quite sturdy and has a 40 inch gantry.
It has three step-syn motors. One has 6 leads and the other two have 10 leads. (I counted them twice and there are 10.) One of the 10 lead motors drives the gantry belt. The other 10 lead motor was to friction feed the paper and drove a shaft going the gantry length. The smaller motor was to change out the plotter pens.
On the gantry to move the pens down is an electrical solenoid.
I have stripped it down from being a pen plotter and now need some information on the motors in order to go any further.
The 6 wire square motor is part number / Type 103-541-0144. It has 24 volt, 0.2a, 1.8 deg/step on it. It does look NEMA 17 size and is 30 mm between bolts. Measuring resistance, I found the following;
Blue White Orange
Blue - 124 0.248
White 124 - 124
Orange 0.248 124 -
Yellow Red Black
Yellow - 0.248 124
Red 0.248 - 124
Black 124 124 -
What type of motor is the 6 lead? I found a Parker picture that seems to make sense of the resistance as a Bifilar winding. I assumed from that article that it is bipolar.
The other two are identical round motors except the plastic gears. They are double ended shaft and seem to have some sort of plastic flywheel on the non-gear ends. They are part number / Type 103-7555-54D0. Ratings are 0.78 volt and 0.6 amps, 0.45 deg/step. These two are bigger at 47 mm between bolts on a side. Measuring resistance, I found that there were 5 pairs of wires that each had 1.2 ohms. No other combination of wires gave a resistance. The pairs were a solid color wire and then a white wire with the solid color spiral on it.
What type of motors are the 10 lead motors? In all of the threads and links, I didn't come across this number of leads.
Is there any decipher of the part numbers? Google didn't get me anything for these part number ranges of motors. One breakdown for step-syn had the initial two digits being the NEMA class, third digit being amps and the next set of numbers being the ounce holding rating.
If the number sequence is correct for this old of motors, is the 0.2a and 0.78a for the voltage they are being used at? If so what is the voltage for the 3 amp use? I have a number of power supplies to choose from
While moving the pen mounting plate across the gantry didn't probably require much, the moving of paper off a roll should have been a meaningful load. It would be helpful to know the ounce ratings for these.
Hope someone can help.
Steve.
