586,655 active members*
2,790 visitors online*
    Stainless spring
    Is there a type of stainless that is:
    Machinable
    Has decent spring characteristics
    Doesn't need heat treat after machining
    I need to make a stainless collet
    John
    Sep 2008
    229
    "Spring" is more about design than material. Traditional spring materials are defined by having a high ratio of yield strength to tensile limit, but that just makes them more efficient as springs.
    To further complicate matters, "machinable" is a rather woolly concept, and the existence of CBN (Cubic Boron Nitride) and diamond tipped tooling has stretched that boundary in much the same way as Carbide did, and High Speed Steel before that.
    Have a look around www.matweb.com Perhaps 440C would do what you need.
  1. Spring Winding DIY ? How to
    By MHINK in forum Bending, Forging, Extrusion...
    Last Post: 02-11-2008, 01:34 PM
  2. Gas Spring Specs
    By Chrisjh in forum Syil Products
    Last Post: 02-09-2008, 05:03 PM
  3. HL1 Counterbalance Spring Broke
    By Geof in forum Haas Lathes
    Last Post: 07-26-2007, 06:37 PM
  4. Gas Spring Counterbalance (Swede???)
    By bill south in forum Mechanical Calculations/Engineering Design
    Last Post: 07-06-2006, 10:26 PM
  5. I need a u-nut / spring nut / j nut
    By ljoe1969 in forum Community Club House
    Last Post: 02-06-2006, 10:12 PM
