Hello, this is my first post. Hope I'm doing this right.
Anyhow, I have two mastercam 4-axis problem. First one is that when I post the 4-axis toolpath I get the correct x and y coordinates for 2 out of the 4 sides that I am machining. The 2 incorrect x,y coordinates are the exact opposite as the correct coordinates. An example would be, the correct x coordinate would have a positive value, and the incorrect coordinate would have a negative value. The same goes for the y.
The next problem is, instead of getting a, A90.,A180.,A270., or A0.0, I get G54,G55,G56 and G57. I have the rotary axis turned on. I've tried messing with tool planes and construction planes, but no luck. Could use some help.
Bob
