Does anybody nsell projet boards that let u wire in a surface mount iC into a larger environment? After searching for an LED flasher that can run on 3v. and be slowed down to use in a small garden lighthouse, it appears that without a way to mount a tiny little IC this "perfect" circuit is unbuildable.
http://www.edn.com/article/CA601829.html
Does anyone have a better idea for a slow flash LED flasher? The original electronics from this solar powered lighthouse were ruined with water and decay. Some parts are unidentifiable. It looks like a simple two transistor flasher, but there are added bits for the solar charger, and photo diode for dusk to dawn operation. Reverse engineering is further messed up due to all the leads breaking off from corrosion.
