586,510 active members*
3,288 visitors online*
Results 1 to 16 of 16
    May 2009
    6
    laser engraving on anodized aluminum
    Hello,
    I am new to laser etching/engraving. I work at a machine shop that has a 40W laser engraver. I have been trying to get a nice crisp logo (25mm x 2mm) on black anodized 6061 and 7075. I can get a pretty good looking logo, but it appears more blue/grey than white. Other parts that I see the laser etching is really white.
    I've been playing with the dpi setting, speed, and the power settings. More power seem to turn the etching brown. Too little power and the logo barely appears. Speed doesn't seem to affect it at all.
    Any suggestions?
    Thanks,
    Chris
    Feb 2008
    123
    This may be an obvious question, but have you tried adjusting the focus of the laser instead of the power?
    We have a very similair setup and have run into this issue in the past. That is how we fixed it.
    May 2009
    6
    Yes, I have. It seems like the power and the focus are linked. I've been trying to keep one variable constant and changing other to see if I can work this out.
    I currently have my lens about 54mm from top of part. This seems to get me the smallest laser point. If I bring the lens closer, say to 52mm, the etching comes out blurry at any power. If I leave the lens at 54mm, more power makes etching brown and blurry.
    I'm stumped. Are there more variables I can adjust?
    Dec 2008
    1258
    First, make sure it is regular black and not 'hard' anodized as that is almost impossible to remove cleanly.
    Second, use 2-passes to get a nice clean result. The initial pass will remove 90% and leave it grey but the follow up will clean it up nicely.
    Zax.
    Feb 2008
    123
    Quote Originally Posted by zax15uk View Post
    I was just about to ask this as well. I was thinking that maybe the problem lies with the part rather than the machine.
    May 2009
    6
    pretty sure these parts are not hard ano.
    I'll try two passes
    does anyone have any general settings to use for engraving on anodized aluminum? low power high speed? 500 dpi?
    thanks
  1. Engraving anodized aluminum - color fill?
    By Neil_J in forum Hobby Discussion
    Last Post: 09-17-2008, 03:11 AM
  2. Nickel plating on anodized aluminum
    By stag53 in forum Mass finishing equipment/media/strategies
    Last Post: 04-08-2008, 11:00 PM
  3. Engraving in anodized aluminum
    By fish09 in forum Engraving Machines
    Last Post: 08-24-2007, 10:02 PM
  4. engraving anodized alum
    By srmaietta in forum Engraving Machines
    Last Post: 03-02-2007, 10:23 PM
  5. Anodized Aluminum Round Rod - Best Place To Buy It?
    By nlh in forum Material Machining Solutions
    Last Post: 12-02-2005, 04:54 PM
