586,596 active members*
3,035 visitors online*
Thread: masking film
    Jan 2004
    201
    masking film
    a friend showed me a type of tacky paper to put on the back of wood sheets to prevent smoke and burn marks from the laser. easy to peel off after cutting.
    It was probably 24" wide.
    what is this kind of "masking paper" called and where do you buy it?
    thanks
    jv
    Dec 2008
    1258
    It sounds like 'application tape' used to apply vinyl signage.
    Check your local sign supply store, it's cheap and available in various widths - also in high and low tack. Make sure it's the paper stuff though as a lot of companies are moving to clear (PVC) for easier application.
    Zax.
    Dec 2006
    10
    Quote Originally Posted by zax15uk View Post
    Zax.
    You can find it at most places that sell vinal for sinage, it could also be called 'transfer sheets'
    The ones that i get are usually 6" x 300' rolls and usually cost around 25$ -30$
  1. Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 08:15 AM
  2. Looking for a masking film for soft stone and wood.
    By Larne W in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-16-2008, 03:08 AM
  3. Slitting pre-patterned film at angle on stage
    By mfield in forum G-Code Programing
    Last Post: 06-25-2008, 01:11 PM
  4. Professional Plastic film, sheet, bags supplier!
    By casung life in forum News Announcements
    Last Post: 11-27-2007, 12:08 PM
  5. Masking machined parts using vinyl
    By Brookway in forum Mass finishing equipment/media/strategies
    Last Post: 07-02-2007, 06:30 PM
