586,361 active members*
3,560 visitors online*
Results 1 to 13 of 13
    Jul 2008
    19
    Spur Gear indexing
    I need to machine a spur gear with 106 teeth. I'm not having a problem calculating diametral pitch, addendum, etc. nor figuring what pitch cutter to use. My problem is with the indexing calculations. I'm using B & S plates with 40:1 ratio. Per the machinists handbook, 106 target divisions require 1 full turn plus 7 holes on 39-hole circle + 29 holes on 41- hole circle. I know 40:1 means that 1 full rev of the indexing head = 9 degs and no probem calculating up to 40 divisions. The number of divisions over 40 requiring partial turns is confusing me. Could someone break it down step by step?
    Thanks!
    Mar 2006
    2712
    Jul 2008
    19
    Thanks for the link. I can do the easy ones, I wish he had given an example of compound indexing like the one I'm working.
    Mar 2006
    2712
    Compound indexing?
    Dick Z
    DZASTR
    Jul 2003
    1220
    The nearest with a 40:1 Ratio and std plates.
    Use 16 holes circle and rotate 6 holes.
    This will be 4 holes short at the end so suggest you advance 1 hole at tooth 26,53,79,106.
    Dec 2008
    3111
    I'm confused, 106T
    If one turn = 9°
    & 40 turns = 360°
    If I cut at eact turn, I would get 40 teeth ( correct )
    then
    How many teeth do I get at 1 full turn plus 7 holes on 39-hole circle + 29 holes on 41- hole circle.????? ,,,my guess is something less than 40 teeth
    my calc is 40/106 = 20/53 = 20 holes on a 53 hole plate just over 1/3 of a rev.
    here's a link page 105
    Jul 2003
    1220
    Looks like 21.2 teeth.
    If this 21.2 cycle is repeated 5 times this gives 106.
    Not sure how this works and if all the teeth are evenly spaced?
    Jul 2008
    19
    That is the way I calculated it Superman. I'm using Brown and Sharpe standard plates with no 53-hole circle. I see in the Machinist's Handbook that Cincinnati plates have a 53-hole circle. Sorry for the confusion but I got my info that I posted from the Machinist's Handbook from the "Simple and Compound Indexing with Brown and Sharpe Plates" chart found in the Milling Machine Indexing chapter. I guessed that 106 target divisions would be the same as "106 teeth."
    Dec 2008
    3111
    Finally found what you need - bad news is..... it's a Cincinnati
    But it has how it is calculated PAGE 214
    http://books.google.com/books?id=dhX...um=7#PPA214,M1
    If the link doesn't work, r-click on it, properties, copy the "Address URL" section, and paste into the address bar
    Jul 2003
    1220
    Here is a good article on Compound Indexing. Also a chart of the Index Movements. Page 143 on.
    http://books.google.co.nz/books?id=N...um=9#PPA143,M1
    Feb 2009
    6
    I posted this before but it is pretty simple.
    If you don't have a 53 space circle, print
    one out on paper and stick it to a plate and move
    your index pin and sector arms by eye.
    Any error is reduced by 40 to 1 through your gearing.
    Keep going in the same direction to avoid back-lash and
    if you do over-shoot, back up some and try again.
    Clamp the head while cutting and have no distractions
    at all.
    Best Regards, Charlie
    4826
    ...have no distractions at all.
    I'm not clear on how you do this last part
    Jul 2008
    19
    Thanks for the help everyone, I knew I would get help here! Excellent reading in the links you posted Kiwi and Superman! Will start cutting chips tonight.
  1. Simple spur gear design
    By kentavv in forum MetalWork Discussion
    Last Post: 07-10-2014, 02:51 PM
  2. Making a four stage spur gear box? (how to )
    By youthreewire in forum Mechanical Calculations/Engineering Design
    Last Post: 02-27-2009, 04:11 AM
  3. ..the teeth on a pinnion spur gear...
    By malJohann in forum Mechanical Calculations/Engineering Design
    Last Post: 07-13-2008, 10:22 PM
  4. Spur gear availability?
    By 2fst4u in forum Waterjet General Topics
    Last Post: 04-02-2007, 02:46 PM
  5. Spur Gear / Gear Rack
    By ckrantz in forum Linear and Rotary Motion
    Last Post: 12-07-2006, 06:06 AM
