Hello everybody.
I'm new to the community and to CNC. As you can guess I have some problems. The first is how to post messages. (post quick reply?) (go advanced?) I'm new to forums too.
I posted a similar message today but it went to the wrong forum. At least I found the proper place to post or I hope I did.
I'm running Mach 3 with Gecko 201 drives on a home built table. I modified a tiny G code file to cut five identical circles. The first circle does not complete where it started by has a small offset in X and Y. The four additional circles look like I stepped on a Slinkey. I even reloaded and upgraded my Mach 3 with no benefit then used another computer. This is some sort of cumulative error involved here. The digital readouts still give the same coordinates but the positions have actually shifted.
Is there somebody that can tell me what's wrong?
Next problem: Where can I get a small solid state relay that will be triggered by the 5 volts at the 'bob' and control the 120 volt AC that drives a spindle motor?
I've been curious about 2.5 dimensions when dealing with cam. Would somebody with a lot of wind explain what this really is and compare it to 3D?
Thanks for any help and I want to repeat again that I'm glad to be here.
John
