586,988 active members*
3,699 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > New User Questions - CAD
Results 1 to 9 of 9
    Jan 2007
    435
    I just recently started using bobcad v23 and I'm trying to get started with some basic drawings. I went through the short tutorials presented without any problem.
    It may be that I'm used to Alibre and the functions I'm looking for just don't exist in Bobcad. For instance...
    Does bobcad not support constraints? In Alibre if I sketch to lines, one above the other in the xy plane I can simply select the two lines and add a parallel constraint to them. They will suddenly snap to be parallel to each other. I can do the same with angles, etc. in Alibre. Is there no way to do this in bobcad?
    Dimensioning in bobcad seems very odd as well. In alibre the dimensions aren't drawing entities. They work almost like constraints. If I draw a line in Alibre and add a dimension to the line for length, it will indeed add a dimension showing the length of that line. If I want to change the length I just double-click the dimension and change it, voila the line will match the the new length I typed in the dimension. With bobcad the dimensions only seem to be for viewing the dimension, not setting it. They also appear to be drawing entities.
    Another oddity. If I use the "angle line" function in bobcad to draw a line at an angle to another entity, it asks me for the angle to use when creating the line. It will then draw the line at this angle. Great. But if I want to change the angle after the line is drawn I try right clicking on the line and choosing to "modify entity." Instead of having a box to change the angle I can only change the start and end points of the line in both the x and y axis. How can I simply change the angle of the line without deleting it and drawing it again?
    Dec 2008
    4548
    Quote Originally Posted by TravisR100 View Post
    In BobCad this is done at design time
    Yes
    This history mechanism in BobCads Cad side does not perform like this yet.
    These functions are not parametric.
    Dec 2008
    4548
    With that being said, you can always change the angle of any entity with the rotate or 3d rotate commands. It's just a different way of looking at it.
    Jan 2007
    435
    Thanks for the response. Another question. Let's say I start with a 2d drawing. I define the stock. I create a rectangular pocket. If I now want to fillet the pocket in z (in other words the angle between the xz and yz, not xy) do I have to start over as a 3d solid?
    Jan 2007
    435
    Also, any easy way to draw a hexagon? Octagon? x sided polygon of any sort?
    Jan 2007
    435
    Disregard post #4. It appears I can use the "extrude surface" command to accomplish this.
    Jan 2006
    4396
    BobCad does not use Parametric Technology. Therefore you can not edit features in a Drawing or Design.
    Your better off creating your Design in Alibre then Exporting to your V23 to do the machining.
    Or you can get Alibre Cam (which is Visual Mill) and have Parametric CAD and CAM.
    The choice is yours to make.
    Toby D.
    Schwarzwald
    www.refractotech.com
    Jan 2007
    435
    Thanks Toby. Yep, looks like I'm going to have to create the parts in Alibre then import them into bobcad for machining. The drawing tools on the CAD side in bobcad just seem extremely cumbersome to use. I suppose it's just what one is used to.
    Jan 2006
    4396
    That is probably your best bet considering you would have to spend more on the Alibre Add-On Module.
    Toby D.
    Schwarzwald
  1. New User questions
    By TheRo0sTer in forum Haas Mills
    Last Post: 09-25-2008, 07:45 PM
  2. New IH user questions
    By ccmind in forum Charter Oak Automation Support Forum
    Last Post: 11-18-2006, 07:27 PM
  3. new user questions
    By alchemist in forum Charter Oak Automation Support Forum
    Last Post: 11-18-2006, 05:17 AM
  4. New user questions
    By John F in forum OneCNC
    Last Post: 06-27-2003, 04:13 PM
