586,655 active members*
2,814 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Could someone post there setting for a HY02D223B
Results 1 to 7 of 7
    174
    On my readout it says 11,520 is my max rpm when it is running at 400hz. I must have something set wrong on my 2.2kv spindle.
    Apr 2008
    384
    Do you have it set as 2 poles ?
    174
    No I have it set for 4 poles.
    Apr 2008
    384
    Then setting it as 2 poles should fix it. It looks like it would only read up to 23,040RPM though so I don't know where the other 1,000RPM has gone.
    174
    What is pd144 suppose to be set at.
    Apr 2008
    384
    I'd think it's 3,000 as it's the speed at 50Hz.
    (As 400Hz is 24,000RPM.)
    174
    That was it.
    Thanks Alot
  1. Help with Huanyang HY02D223B
    By stevespo in forum Spindles / VFD
    Last Post: 02-01-2014, 09:42 AM
  2. Setting 142
    By behindpropeller in forum Haas Mills
    Last Post: 03-10-2009, 04:52 PM
  3. Setting Z in G54
    By bloefeld in forum Haas Mills
    Last Post: 08-26-2008, 03:01 PM
  4. Help setting up post process from TCC to Mach3
    By 56speedster in forum Uncategorised CAM Discussion
    Last Post: 03-29-2008, 04:14 AM
  5. Setting Zero
    By wjbzone in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-03-2004, 11:25 PM
