any way to home the A and B separate when I power up and home out
I have large parts that will crash when the A and B home out .. but some take
days to machine
I dont like to leave my machines on over night we get bad lighting storms here
days to machine
Use Zero Return Single axis.
Do not push Auto Restart when you power up, just Reset then Zero Return, A or B then Singl Axis. Home all your axes individually this way.
You may also need to use the "Jog without Zero return" setting 53 to ensure you do not have a collision. But be careful that you do not over travel an axis - you could break something.
