I asked before, but the discussion got side tracked. )
Is there a chart somewhere, or rule of thumb that tells me how fast I should spin a diameter of Acme threaded rod to keep wobble out?
As of right now I'd like to run steel 1/2" acme, 5ft long at 200rpm, captured on both ends with a ball bearing and a thrust bearing. Any thoughts? What is the max revolved speed of 1/2"?? 5/8"??
Thank you,
