586,357 active members*
3,986 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > THB6064H(4.5A)-Stepping Motor Driver IC 4.5amp
Page 10 of 10 8910
Results 181 to 185 of 185
  1. #181
    364
    Re: THB6064H(4.5A)-Stepping Motor Driver IC 4.5amp
    I can't find a real datasheet for these motors.
    Looks like the current setting is to high for series connection.
    It would be better to use the half-coil connection and keep the 1.5Amp current setting, this will also increase the torque at higher speeds .
    Using slow decay should reduce the motor heat a bit, the current ripple is lower and this reduces the losses in the motor.
    Hope this helps,
    Luc.
    Open source CNC electronics and accessories:
    http://users.skynet.be/ldt/CNC%20electronics/THB6064AH.html
  2. #182
    Oct 2011
    27
    thank you very much!
    Not finding a proper datasheet bother me a lot too....I looked everywhere....but I'll certainly try those changes you said.
    By slow decay what do you mean? I have 20% - 40% - 60% and 80% setting
  3. #183
    364
    Sorry for the late reply.
    The motor heat is caused by the incorrect current setting for the series connection,
    20% decay will generate less heat than 80% but this will be marginal.
    Did you try the half coil connection as recommended?
    This is the best configuration considering the relatively low 28V supply.
  4. #184
    Oct 2011
    27
    I've not tried the half coil connection yet but I did lowered the current at aprox 1.1A and it works. Although it's only 0.4A lower the motors are dead cold and still have a reasonable torque.
    My PSU can go as far as 36V. Should I push it beyond 28V or leave it there if it does not skip steps ?
    I'll also try the half coil connection when some connectors that I've ordered will arrive. Now I have to re-solder the motor wires which is not quite convenient.
  5. #185
    May 2005
    1397
    Great to hear it's working. Higher voltage gives higher speed (but may cause mid band resonance). If it works, I wouldn't change it. Good motor connections are critical. A motor lead coming loose while running can fry a driver.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
Page 10 of 10 8910
  1. TB6560HQ-Stepping Motor Driver IC 3.5amp
    By NASR1 in forum Open Source Controller Boards
    Last Post: 03-30-2015, 10:02 AM
  2. Stepping Motor Driver IC THB6064H
    By lihaijiang in forum Engraving Machines
    Last Post: 07-07-2009, 03:49 AM
  3. THB6064H stepping Motor Driver IC4.5A
    By lihaijiang in forum News Announcements
    Last Post: 06-22-2009, 03:29 AM
  4. Stepping Motor Driver
    By MR MOTION in forum Stepper Motors / Drives
    Last Post: 05-17-2009, 06:13 PM
  5. 80V 6A Micro stepping Motor driver
    By eded59 in forum Stepper Motors / Drives
    Last Post: 07-31-2007, 03:43 AM
