586,246 active members*
3,769 visitors online*
    Jun 2006
    44
    Sub Spindle Issue on SQT15MS
    I just had my machine repaired today and everything seems fine. Everything is working fine in manual mode. The issue I have is with the Sub spindle in manual / Rapid mode it spins fine in both directions at whatever speed i select. The trouble is when I use M303 or M304 (with an S value of anything) in either a program or with the test button it won't move it just seems like it is trying to move, you can't move it by hand it's solid. It seems strange beacuse it spins fine in rapid or manual mode in either direction. M306 and M307 (Chuck open / Close)work fine. Any ideas ?
    Feb 2007
    198
    I'm clueless. Sounds very unusual and may be a by-product of your latest repair?
    Does the spindle work in manual jog mode? Opps - you do state it jogs both ways just fine. My bad
    -jim
  1. X3 Spindle Issue?
    By chns in forum Benchtop Machines
    Last Post: 11-27-2008, 12:58 AM
  2. How do you like mazak sqt15ms
    By UZU-90 in forum Uncategorised MetalWorking Machines
    Last Post: 03-29-2008, 11:51 PM
  3. fanuc spindle motor issue
    By will_lewis in forum Servo Motors / Drives
    Last Post: 01-22-2008, 01:08 PM
  4. Super X3 Spindle Issue
    By dafowfidy in forum Syil Products
    Last Post: 01-09-2008, 08:17 PM
  5. SQT15MS T-Plus Sub Spindle
    By chips-ahoy in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-30-2007, 12:37 PM
