587,058 active members*
3,693 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Hawk150-Acramatic2100 "NC Engine Failed"
Results 1 to 14 of 14
    Jul 2005
    15
    Red face Hawk150-Acramatic2100 "NC Engine Failed"
    We have this machine Hawk that had this power failure on the CPU and the PSU doesn't work anymore.
    After replacing the power supply with a new one, now the machine errors on the diagnostics with "nc engine base failed". After that on the screen with the report displays this:
    Bridge board RT Unknown
    Conv Servo Unknown
    High Density I/O Unknown
    Pendant Panel Unknown
    Real Time Processor Unknown
    There some info on this here, but the flash of the cmos is need it.
    http://www.cnczone.com/forums/showthread.php?t=53762
    Maybe i can get a hold of hawk150 from a local company, and if there's a way to read the cmos from that computer and try to fix mine.
    Any help is appreciated......Thanks
    Jul 2005
    15
    We check the RT MB and found the CMOS to be corrupted.
    The way to fix this doing a hot-swap flash, but it has to be with a similar motherboard G7VP2. Since I couldn't get a similar board, I bought one from ebay.
    My only concern is "what if the cmos it was especially program for this machine"
    Any info on this please post or point to the right direction...thanks
    Jul 2005
    15
    Guys we really need your help.
    With the new motherboard, the machine now fails test on the Conv Servo . We already check the servo and is good. Check the motherboard in another lathe and we get the same error, so I think is the settings on the bios of the MB.
    Does anybody have the correct bios settings for this MB G7VP2.
    ...Thanks
    Nov 2006
    251
    hawke 150
    Did you have the same probs before you replaced the power supply and did you use a power supply compatible with the one you replaced and have you tried to reseat all the computor boards.These things can cause some really weird errors to come up on the screen.Best of luck greg
    Jul 2005
    15
    Already try another rt mb from another hawk150 and it does work.
    That confirm thet our new MB is not working correctly because of the bios settings and i already play with this and stil can get the comunications to work and fails at conv servo.
    This week going to try move the bios settings but thru MDI option.
    Jul 2005
    15
    Machine is working again
    We email siemens and they send the configuration file back.
    Now the machine is working again.
    Oct 2008
    123
    g7vp2 cmos
    hello i am trying to fix my g7vp2 board as well but with no success.
    any chance you could send me the configuration information you had from siemans.
    regards
    mallardfizz
    Jul 2005
    15
    Shure can PM your email.......
    Oct 2008
    123
    realtime timeout
    hold fire i think i've cracked it.
    thanks for the reply
    regards
    mallardfizz
    Apr 2009
    32
    I am struggling with the same situation too. Conventional Servo fails every time. I am trying to replace with a new motherboard(different brand). Can anyone here post the BIOS settings as a setup guide?
    Regards
    Apr 2007
    5
    Re: Machine is working again
    Hi espinja,
    Hi have a machine with the same problem.
    Can you please help.
    Thanks.
    Jan 2016
    5
    Re: Hawk150-Acramatic2100 "NC Engine Failed"
    Dear espinja,
    I think I have exact same issue. Will you be able to send me the CMOS configuration setup which you got from siemens.
    If you could explain how you done it in here it could be very beneficial for the novice cincinnati owners like me.
    Thank you have a pleasant day...
    Nov 2004
    22
    Hello,
    I have the same problem here. I changed the battery on both cards and the NC Engine Base error appears.
    Can you help me?
    Best regards
    Dec 2022
    Hello!
    I'm having the same issue as you guys. Do you mind sharing your solutions?
  1. Making Large "Turner's Cubes" on an Engine Lathe
    By widgitmaster in forum MetalWork Discussion
    Last Post: 08-13-2019, 08:40 PM
  2. EZ-trak DX "POWER ON FAILED"
    By john_hoek in forum Bridgeport / Hardinge Mills
    Last Post: 05-22-2014, 04:25 PM
  3. Bridgeport Ez Trak "power on failed"
    Last Post: 10-11-2013, 11:41 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. "Security Device Invalid or Has Failed"
    By xray34 in forum HURCO
    Last Post: 08-03-2010, 09:16 PM
