where in mach 2 can you reverse the direction of you axis so that going in a certain direcion is + instead of - ?
Should be in "config" menu >> Motor reversals.
Regards Terry.....
The other way is to change the "Low Active" check box by the DIR pin.
FYI, This is the only way to do it in Mach3...
Happy ChipsOriginally Posted by senor J.
Brian
