587,067 active members*
3,655 visitors online*
Results 1 to 9 of 9
    Oct 2008
    105
    4th axis wiring questions
    I have a TM-3 and am wanting to pc together a 4th axis. I have found a servo amplifier and need to see an example of how the 4th axis integrates into the machine. I guess any vm would help, but I would love to find someone who owns a TM and has the 4th axis wired in. I need pics of the parts/wiring and part numbers of the actual cables. Any help would be greatly appreciated.
    Nov 2007
    1702
    I think you have to also have the unlock code (4th axis enable) for the control, so even if you get through all of that, it won't work.
    If you have the amplifier, the only missing piece is the cable from the amplifier to the side of the cabinet. Power and logic control are the same as you see on the other axis amplifiers. Power just jumps from one to the next if I remember correctly.
    Greg
    Dec 2008
    319
    I think on our TM you can just turn the 4th axis on.
    Nov 2007
    1702
    Doh! Wrong thread.
    Greg
    Nov 2008
    19
    tm3
    just finished wat ur doing with 4th axis HA5C indexer on TM3 can take pics if u want
    Pictures
    Please post pictures of your project.
    John
    Oct 2008
    105
    Absolutely I want to see pics. And did you need a code to unlock 4th axis or was it just a setting that needed to be turned on? Thanks.
    Dec 2008
    319
    Quote Originally Posted by WGJ View Post
    I have been through all of my settings several times in the last month and I am 99% sure it is just a setting to enable 4th axis.
    Tim
    Jul 2005
    340
    you have 99% right :-) in settings you can turn the 4th axis BUT indexing axis , not one , you can have more
  1. More questions on wiring. :)
    By bkboggy in forum DIY CNC Router Table Machines
    Last Post: 04-10-2009, 05:12 AM
  2. Questions about wiring
    By Phife in forum CNC Machine Related Electronics
    Last Post: 04-05-2009, 07:40 AM
  3. Gecko 540 wiring: Questions
    By CROSSHATCH in forum Gecko Drives
    Last Post: 09-28-2008, 05:52 PM
  4. Wiring Breakout Board Questions
    By Dingo745 in forum Xylotex
    Last Post: 03-31-2008, 08:47 PM
  5. Wiring Questions
    By cnc2k in forum CNC Machine Related Electronics
    Last Post: 11-28-2004, 12:45 AM
