586,345 active members*
3,227 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > How do you check the control cabinet's cooling fan on an SL-10?
    Oct 2003
    530
    I replaced my control cabinet's filter on my 02 sl-10 today. I wanted to verify the cooling fan was working but apparently it goes on intermitently. I checked it a bunch of times during the day but it was never on. Anyone know how to check the fan to see if it's actually working. Is there a setting somewhere or a relay I can push to test?
    Apr 2008
    65
    There is a temp sensor in the control cabinet. If the control gets warm the fan will come on. I would trace the fan wiring back to the Power PCB and move the plug to a 90C plug on the PCB, should be 120vac and that should immediatialy turn on the fan.
  1. need help with cooling fan please
    By johnt in forum CNC Machine Related Electronics
    Last Post: 03-12-2009, 03:12 AM
  2. TRM Cooling
    By Alex Westling in forum Fadal
    Last Post: 12-12-2007, 10:18 PM
  3. air cooling??
    By moreil in forum Uncategorised MetalWorking Machines
    Last Post: 07-02-2007, 12:12 AM
  4. Replies: 3
    Last Post: 01-19-2007, 02:59 PM
  5. Air Cooling?
    By senor J. in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2005, 03:05 AM
