586,409 active members*
3,015 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
Results 1 to 8 of 8
    Jun 2007
    8
    Hello All I Very Like Make a Little Cnc Machine
    but i have problem is to
    Please See The Picture Below
    Hardware
    I buy 3 Axis Stepping Motor (Start Shaphon 23HS3002)
    My Motor
    Buy 3 Step Driver (MS-2H057M) And Set It
    My Drive
    Buy Pmdx-122 and Set It
    Assembly In Box Below
    Buy Dc 9V Adaptor
    Conect Stepping Motor to conector
    Connect All To Box and Pc By Db 25
    Software
    Install Win Xp sp2 And Optimisation it
    Install Mach3 VR2.42
    Conect pc to Board (Pmdx-122 )
    restart System
    (when System restart Relay in Board is On&Off )
    Run Driver Test And Pic S1 in Below
    Run Mach3Mill
    1- Config - select native Unit and select MM's
    2- Config -Port And Pin - Pic Below
    3- I don't know, how set Motor tuning and other config . I have a problem - Motor in not work Properly. Film in Below
    Do You Help Me .
    tank's a lot
    Jun 2007
    8
    Talking
    Film Of Moto Below
    Attached Files Attached Files
    May 2006
    573
    I think your stepdrive is set way to high, as far as i can tell its set at 8000 steps per rev, try setting it to the lowest value = 400 step per rev. In mach 3 set step per unit to the same, 400 and increase acceleration to maybe 100. Now in the MDI enter G0 Y1 and the motor should spin one full turn.
    Also make sure you have set the Unit in the config menu to mm not inches
    Jun 2007
    8
    Quote Originally Posted by Guldberg View Post
    Hello Guldberg
    But I Think On Dip
    On (down) = 0
    Off = 1
    do you think unlike
    Apr 2007
    6
    I think On is 1 and Off is 0
    Switch 5 needs to be set off to use Step and Dir mode
    May 2006
    573
    Maybe your right, its a bit hard to tell from the picture. I would still try and set the step per unit to the same as the step driver. And you have the mm setting correct? 4 is still way to low for acceleration.
    Jun 2007
    8
    Hello EveryBody
    I detect Problem & crash Sound
    the wire Of A A_ b b_ is malapropos
    Then
    In config - motor tuning and setup change
    Step Per : 400
    Velocity :100
    Acc : 30
    Step Pulse : 0 What is this?
    dir Pulse : 0 What is this?
    Then Motor rotate Corectly
    -but Only rotate Left To right if is X Axis more
    not Rotate Right to Left when X is less
    Where problem ?
    in the course of Dip On Step Driver On=0 Off=1
    May 2006
    573
    Not sure i understand correct. X axis more than what? Does it always rotate the same way no matter what you do?
  1. Mach3 motor tuning question
    By kn6398 in forum Machines running Mach Software
    Last Post: 06-10-2014, 09:21 AM
  2. motor tuning problem
    By m8kingit in forum Mach Mill
    Last Post: 04-29-2009, 03:39 AM
  3. Replies: 1
    Last Post: 10-17-2007, 05:16 PM
  4. Motor tuning under Mach3
    By BAustin in forum Charter Oak Automation Support Forum
    Last Post: 12-24-2006, 06:23 AM
  5. Mach2 motor tuning problem???
    By kombayotch in forum Mach Mill
    Last Post: 03-15-2006, 09:34 PM
