586,317 active members*
3,257 visitors online*
    Apr 2009
    Calculating tool life
    I am trying to calculate the tool life for a part designed in SolidWorks and milled in SolidCAM.
    What are the parameters and formulas that I must have to do this?
    I have
    - The part material (Mild Steel (CQ))
    - Feed Per Tooth (what are the units for this one?)
    - Surface cutting speed (m/min?)
    Any help or "pointing in the right direction" appreciated.
    Cheers
    Apr 2009
    Can I use Taylors Basic Equation?
    (V)*(T^n) = C
    where T = tool life
    V = cutting speed
    C and n are available from reference sources
    does anyone have any experience with this formula?
    156
    Re: Calculating tool life
    The "Manufacturing Planning and Estamating Handbook on page 6-56 has a table 6-20.
    T is in minutes and C is the calculated constant.
    V is in SFM.
    The table gives the n value to use.
    Work Material, Sinistered Carbide, High-speed steel.
    Steel, soft .20 (this value using 300 FPM), .12
    Steel, hardened .25 , .15
    Cast iron .25 , .15
    Light metals .41 , .41
    The table gives those values for a 60 minute tool life, .009 ipr and .062 depth of cut for HSS.
    Carbide using .010 ipr and .100 depth of cut.
    For guesstimation I have just used .25 for Carbide cutters and .1 for HSS, and what ever FPM and IPR and the apparent tool life I was getting in minutes and change T to what I want to change for a guess at a new FPM
    Jul 2019
    8
    Tool wear usually includes the following types:
    1 flank wear; 2 scribe wear; 3 months gingival wear; 4 cutting edge blunt; 5 cutting edge chipping; 6 cutting edge crack; 7 catastrophic failure.
    Therefore, steel also determines the life of the knife. If you need good steel, you can contact Songshun Steel.
    Contact:https://steelpurchase.com/about/
  1. Thru-the-tool coolant - tool life
    By pwilson101 in forum MetalWork Discussion
    Last Post: 05-22-2012, 08:51 PM
  2. what to take into consideration when calculating tool speed and feeds
    By prodigy86 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-04-2012, 12:55 PM
  3. Calculating the arc with tool nose compensation
    By myhäje in forum Mechanical Calculations/Engineering Design
    Last Post: 04-13-2012, 08:58 PM
  4. Renishaw tool offset / break probe and tool life management
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-21-2010, 04:14 AM
  5. Tool Life
    By gmilosevic in forum MetalWork Discussion
    Last Post: 01-04-2010, 04:08 PM
