586,477 active members*
3,619 visitors online*
    Sep 2006
    251
    "E-stop activated" alarm
    Good Morning to all. I have a 1995 EZ-Path Lathe with an alarm. I move the "Z" axis ball screw 1/2" towards home by hand and hit escape, the alarm goes away. The machine homes out great and when I move the "Z" axis 3/4 of the way towards the chuck I get the alarm back. I have found a few broken wires in the wire track (on the back side of Z zxis) and spliced them back together. Now the alarm will not go away at all. I know I have to change the cables, but right now is not a good time. I have also checked the home limit swithes. They were moving slow from coolant buildup at first, but I have resolved that issue. I am wondering what all will cause this alarm. I know low lube oil will, but what are all the others that may cause this. The "e-stop button and contacts are working properly with an ohm meter and I don't see anyting else wrong. Anybody have a list of things to check for? Any help is greatly appreciated.:drowning:
    Thanks, Joe B.
    Just a good ol' boy, never meanin' no harm.
    Joe
    Nov 2004
    3028
    There is a plug at the back of the switch box on the carraige that becomes corroded. Check that as well.
    George
    Sep 2006
    251
    Machinetek,
    Thanks for the post. I checked this as you said and everything pans out. I currently have my Maintenance guy checking for more broken wires in the wire guide. Any other suggestions??
    Thanks, Joe B.
    __________________
    Joe
    Joe
    Nov 2004
    3028
    Check at the AUF board if the 24 VDC is coming back from the Emergency stop switches. If yes, you may have a bad AUF board. Not that uncommon.
    George
    Sep 2006
    251
    Machintek,
    I PM'd you.
    Joe
    Sep 2006
    251
    Problem found!!!
    Quote Originally Posted by machintek View Post
    George
    Hey George,
    I had checked the voltage numerous times at the JP2 connector. It was definitly an intermitant problem. Anyhow, I jumpered wires #91 and #92 to bypass the E-Stop circuit (until I can afford to replace the cables). Thanks for your help. I greatly appreciate it. :wave:
    Joe
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. "Soft Stop" error MPC6515
    By KPBadger in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-25-2009, 08:37 PM
  3. Replies: 2
    Last Post: 06-13-2008, 11:18 AM
  4. Mach2 bombs when I hit the "stop" button
    By Stuff-Builder in forum Mach Software (ArtSoft software)
    Last Post: 09-28-2005, 04:09 PM
