586,852 active members*
2,011 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Help with exporting to dxf
    Oct 2006
    40
    I am using solidworks 2006.
    Using sheet metal to design parts to then cut on my plasma table and form in my press brake.
    I am having a problem with holes in my sheet metal parts not showing up in my material.
    I am opening a drawing of my solid part and selecting flat pattern, then saving as a dxf. when I then open in sheetcam I get a part that has the holes not located on the part. I am puling my hair out here. What am I doing wrong? I also have torchmate cam and when I open in that software I get the same problem that is why I think I am doing something wrong in solidworks.
    thanks
    Dave
    Jan 2004
    3154
    What version of DXF are you saving as?
    I find that version 2000 never gives a problem.
    Although, I have never tried SheetCAM and don't know if any of my suppliers use it.
    www.integratedmechanical.ca
    Oct 2006
    40
    I have tried it in 2000, 2002, 2004 Nothing seems to affect the problem.
    Even if I open the part in autocad and save from autocad, it still has the problem. But when viewing in autocad the drawing is correct..
    I am kind of thinking it has something to do with how the holes are located in solidworks.
    Oct 2006
    40
    Here is a pic of the part in flat and how it shows up in sheetcam after saving as a dxf. You can see just the 3 holes across the bottom of the part are not where they should be.
    Attached Thumbnails Attached Thumbnails solidworks-flat-pattern.jpg   sheetcam-prob.jpg
    Oct 2006
    40
    Ok,
    Did some testing. If I flatten my part and then put the holes in, it works ok. but the only problem with that is when I veiw my part in it's bent form the holes don't show be cause they were created after the flat.
    I know It's probably something I am doing wrong in SW when I am drawing my part.
  1. Exporting Text into Sheetcam
    By Millerman in forum SheetCam
    Last Post: 11-10-2010, 04:27 PM
  2. Saving / Exporting as .dxf
    By harley4ever in forum Uncategorised CAD Discussion
    Last Post: 10-24-2008, 05:52 AM
  3. Help needed exporting to DSTV
    By Mac2309 in forum Uncategorised CAM Discussion
    Last Post: 04-30-2008, 10:20 AM
  4. Exporting drawings from Edgecam
    By kevinmlang in forum EdgeCam
    Last Post: 04-28-2008, 03:46 PM
  5. Exporting BBC V22 file to IGS & Alibre
    By tikka308 in forum BobCad-Cam
    Last Post: 12-02-2007, 11:10 PM
