Hello.
I picked up a Glory GFB-200 Money Counter, at a yard sale for $2. It works fine.
The power supply outputs are labeled +5, +12, and +24, which is exactly what I need for my CNC machine.
Voltage is labeled, but I would like to know how I should go about testing the current.
Should I put the machine back together, and test the power supply's outputs while the machine is on, with my DMM?
Can I just plug the outputs into my breadboard and test the current with my DMM from there, or does there have to be a load on the supply for it to work right?
Thank you.
