586,655 active members*
3,018 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 18i-TA C-axis orientation/referencing/homing/indexing...?
    Mar 2006
    107
    I have ROMI lathe G15SM 2000. y. with driven tools and C axis.
    Control is Fanuc 18i-TA.
    So, here what I want to do.
    First I have to make some operation with milling, than make some turning, and at the end again milling. First milling and second milling must be in relative position, if you know what I mean.
    The problem is, when it returns from spindle mode (turning) to the C mode, spindle is not in the same position as it was before spindle mode.
    On my VMC, when I enter M19, spindle makes few rotations and comes to one pssition, every time to same place (position for tool changing).
    As I know this i called "spindle orientation".
    On my Lathe, when I enter M19 (manual says "Main spindle orientation (active C axis)) noting happens, spindle stays in possition without any rotation. I just hear some little more noise from motor, because C axis is active.
    Sorry for bad english
    Mar 2009
    4
    Try G28 H0 this will return C-Axis to home positiion
    Mar 2006
    107
    Thank you very much, that works
  1. type of motor for A axis - Lathe operation plus indexing?
    By mcArch in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-11-2009, 02:59 AM
  2. indexing 4th axis
    By 69ss396 in forum Haas Mills
    Last Post: 12-03-2008, 10:06 PM
  3. 31i directional 5-axis indexing??
    By medman in forum Fanuc
    Last Post: 09-12-2008, 06:57 PM
  4. c-axis indexing in g-code
    By Plunker in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-13-2008, 12:39 AM
  5. 4 axis indexing
    By camtd in forum PTC Pro/Manufacture
    Last Post: 05-12-2006, 01:20 PM
