hi,
I used lasercut5.3 with laser machine ruijie 1200 X 900 mm, with servodrive panasonic, there is any one for give me all set parameters for well engrave, ( speed start, speed end, space, acc lenght, y acc.......
thanks
laurent
hi,
thanks
laurent
Can you tell us what laser tube do you have (80w?), and what material do you want to engrave?
Maybe I can help you, I have very similar machine.
hi maxxex,
you have similar machine with servodrive?
i used this machine for cut and engrave a diferent thickness plexiglas,
the laser tube is 80 W
No, not with servo drive, I have step motors, but machine size, laser tube and software are the same.
Is that some enhanced version? Does it also use MPC6515 controller?
no the control card is mpc 6575,
this just for control servo drive. in software the control is mpc 6515, and all set is same.
Parameters should be the same, for plexiglas (acrylic) engraving I use speed 400, power 27 and line gap of 0.06 and I get good engraving quality, you should be able to run it even faster since you have servo motors. Do you use PWM or Analog signals to control laser?
I use pwm, do is good?
I would like know the seting in ( work mode, and engrave, in the software, can you send me please
I can't help you much with PWM setting, I can't use them, because when I set to PWM I can't control power when engraving. I use Analog settings.
