586,537 active members*
2,974 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > X4+ More spindle speed by changing timing pulley?
Results 1 to 10 of 10
    May 2005
    925
    Is it possible to increase the RPM to around 5000~6000 RPM by changing the spindle timing pulley to around half its size?
    I still have an original SX3 pulley that came in the spindle motor which is half size of the spindle pulley, using it at the spindle side of the timing belt it should double the speed to around 7000.
    Of course I can get a larger pulley to get around 5000RPM
    Will the spindle support this speed increase? or to rephrase, whats the maximum speed the spindle can handle?
    I see in the Sieg site their cnc machines are offered in 5000 and 7000 RPM
    Pablo
    Sep 2006
    102
    Peu,
    You may have to replace the bearings with a higher rating, but this may not be too much of a drama. I would be interested to hear what Syil have to say regarding this???
    Martin
    Martin
    Apr 2008
    52
    me too
    Pablo, I was just thinking about doing something similar. I know the bearings will not take the higher speeds so I would like to hear from Syil or any body that may have upgraded. Also I am not sure how fast the spindle is balanced for.
    Len
    15362
    Hi Peu
    You want to do away with the timing pulleys & use a poly V belt these are much better than the timing pulleys
    Mactec54
    May 2005
    925
    My question wasn't aimed at whats the best way to do it, I want to know if increasing spindle speed can be done without damaging the spindle.
    Pablo
    15362
    Hi Peu
    You are not going to damage the spindle if you have the right bearing for the speed you want to do & change the pulleys like I said & use a poly V belt for smooth running at high RPM
    Mactec54
    Apr 2006
    844
    mention kx3 spindle 6000rpm.we test it too,when run around one hour the temp very high around 75c~80c.in fact our x4 run this speed also similar temp.so we are in redesign spindle to make a real high speed spindle.
    we are working on that.and test pass,ready to mass production.the noise,temprature total well...
    Direction,Commitment,Follow through
    May 2005
    925
    Hi Xushuo, I want to test that spindle before it goes into production, is a direct replacement of the X4+ ?
    Jul 2006
    741
    Hi, any updates on this?
    I would be interested in having different sets of pulleys on the SX3 for different RPM ranges.
    How does the X4 Speedmaster do it, the spindle that is.
    Thanks.
    Jul 2005
    969
    i think the speed master as a 1:1 ratio with a high speed motor
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
  1. What is a timing belt and pulley ?
    By ynneb in forum FAQ of DIY CNC Machine Building
    Last Post: 02-18-2011, 01:38 PM
  2. Timing Pulley Question
    By SPEEDRE in forum Mechanical Calculations/Engineering Design
    Last Post: 12-24-2006, 04:46 PM
  3. Timing pulley question
    By pstockley in forum Mechanical Calculations/Engineering Design
    Last Post: 04-21-2006, 07:35 PM
  4. Turning a timing pulley
    By bgolash in forum MetalWork Discussion
    Last Post: 03-22-2006, 03:14 AM
  5. Calculating the right timing pulley
    By cnc2k in forum MetalWork Discussion
    Last Post: 09-01-2005, 01:18 PM
