586,410 active members*
3,465 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Victor V center 4 10MA option parameters
Page 1 of 2 12
Results 1 to 20 of 28
    Jan 2007
    5
    Hello All,
    I have a Victor V center 4 10MA and system parameters and PC-NC parameters for this machine are needed.
    The situation with the machine is:
    Our guys tried to clean the electronic parts and accidentally removed the battery in the system !!
    I guess this powered the backup memory which is erased now. The machine locked itself up. There is a CNC service guy working on the machine now. He resetted the machine. Now we need the system parameters, to start the machine.
    Urgent help is needed. Thanks for your help in advance.
    Jun 2008
    1511
    Do you have a hard copy of the original parameters? The MTB usually puts a hard copy in the power cabinet however these usually disappear over time. If not the 3 options you have are 1.to try and contact the MTB if they are still around they should have a file of all the original parameters. 2.Find someone with the same make/model of your machine and control and get the parameters from them. 3.Step through the parameters 1 at a time using your manual and set each one accordingly. The third is a major PITA.
    I can never stress enough that when getting a new or used machine or starting at a new company the first order of business when the machine is first powered on is to backup everything in the control.
    In the event that you get parameters you have to enter your option parameters in first through the IPL mode. This will then get you to the CNC were you can set up your communication parameters and then reload all the parameters. Your counters, timers, keeprelys, and data will have to be loaded by hand.
    Stevo
    Jan 2007
    5
    Problem solved
    Hi Guys,
    Mr. Tony Gannon provided the missing parameters. I thank him for his help. Contact info is below, in case somebody else needs help.
    Tony Gannon
    Victor Europe Ltd U.K.
    Tel: +44 (0) 1706 648485
    Fax : +44 (0) 1706 648485
    www.victoreurope.com
    Best Regards,
    Aug 2010
    Hello sir
    [quote]
    email:[email protected]
    Aug 2010
    need help
    Hello sir
    Aug 2010
    need help
    Hello sir
    Sep 2009
    68
    abrars PM sent
    Feb 2012
    5
    Re: Victor V center 4 10MA option parameters
    Quote Originally Posted by vladimir1409 View Post
    abrars PM sent
    Can i get the PC NC parameters as well for the Victor Vcenter-4
    I need timer keep relay and counters atc program!
    thanking you in advance.
    you can email me at [email protected]
    Aug 2010
    Quote Originally Posted by stevo1 View Post
    Stevo
    can you me help me send parameter of
    v center 4 ma 10 nk 1286
    i will be thanfull
    Aug 2010
    con any one help me to send victor v center 4 ma 10
    parameter NK 1286
    Jun 2008
    1511
    Do you mean load them into the machine?
    Stevo
    Nov 2011
    Stevo
    While trying to do the tool change the error message light is on so now i can run machine in manual mode but not in auto mode . needs procedure to recover the ATC .I mea to say that when i press NC/PC and press ladder .the ladder is not displayed .
    Sep 2009
    68
    sunil8667
    I sent you the manuals I have(on your email) for the victor there is a procedure to reference the ATC you will find in the manual, it should solve the problem with the error light.
    if you don't have the (counter, keep relay, timer etc) parameters you wont be able to use the tool charger
    Mar 2005
    816
    Yeah I remember a friend of mine had one of these Victor's in his shop. It had missing parameters. Parameters were entered and the ATC still didnt work. I dont remeber if he sorted out the timers, relays, etc.
    Oct 2009
    297
    Quote Originally Posted by gbowne1 View Post
    The ATC works when you have a macro program (9000 program)
    Oct 2009
    7
    hello vladimir
    i have same problem with vcenter-4 ATC,please can you email me manuals that you have,i haven't any manuals,erroe led is on and atc don't work,thanks
    and best regards.
    Oct 2014
    137
    Hi vd51,
    What parameters options you interest, please tell private message to me or your PM.
    Mar 2017
    1
    sunil8667
    My Name is Jameel we had purchase Victor V Center 4 VMC six months before and we started the machine unfortunately we lost backup file from the machine how ever we loaded the backup file but techinical people are asking(counter, keep relay, timer ATC Programming) if you can help me out so that we can start our machine.
    Dec 2009
    957
    Quote Originally Posted by jameel123 View Post
    what is the serial number of machine?
    Nov 2011
    Need Help
    I have a Victor V4 vmc with fanuc 10MD control with red cap motor . The serial number is vanished .I do not have manuals for this machine .I could install the basic machine i.e all axes movement .spindle rotaion etc .now stuck up with atc .gave mo6 command the orientaon took place then te pot came down .then the error lamp light glow .and it is not going .also one more problem the ladder is not dislayed ,may be locked .
    need help
    email [email protected]
Page 1 of 2 12
  1. Victor V center-4 Fanuc 10M Help!
    By vladimir1409 in forum Fanuc
    Last Post: 02-10-2016, 12:27 PM
  2. fanuc 10m on a victor v center 4
    By skippyfix in forum Fanuc
    Last Post: 12-03-2012, 08:53 AM
  3. Haas option parameters
    By kenickie22 in forum Haas Mills
    Last Post: 06-25-2012, 08:37 PM
  4. Option parameters on 10T
    By guhl in forum Fanuc
    Last Post: 10-12-2008, 12:39 PM
  5. M32 Option parameters
    By gasto in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-28-2006, 03:44 PM
