586,512 active members*
3,575 visitors online*
IndustryArena Forum > CAM Software > Mastercam > help whith setup sheet
    Apr 2009
    11
    I want to add in my setup sheet if I use coolant and what type it's. I work whit mastercam 9
    Apr 2003
    1876
    Without knowing what post/setup sheet you're using, I'll just give you the code from mine...
    Code:
    	if coolant = 1, 	 "		<td width=69 nowrap valign=top><p><font SIZE=-1>!", popnote, "</font></p></td>", e
    It puts an "!" at the beginning of the Op Type:
    Code:
    !CONTOUR
    Hope this helps, but I'm sure it won't because the chances that you are using the same setup sheet I made is, well... zero.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  1. Setup sheet In Excel
    By sanjeevlj in forum Mastercam
    Last Post: 12-19-2008, 04:43 AM
  2. Need a simple setup sheet for X3
    By foxsquirrel in forum Mastercam
    Last Post: 11-21-2008, 05:08 PM
  3. MCX2 setup sheet????
    By QMI2007 in forum Mastercam
    Last Post: 07-10-2008, 02:41 PM
  4. Setup sheet in Gibbs cam
    By binzer in forum GibbsCAM
    Last Post: 08-23-2007, 02:52 PM
  5. Mastercam Setup Sheet Help
    By stampman in forum Mastercam
    Last Post: 02-27-2005, 02:54 AM
