Originally Posted by
ccm
I've done all the math and understand the wattage & ohm ratings of what I'm going to need and require for my particular senario... but the doc's I have with my board, and what I've read and seen online suggest that the current limting resistor should go on the + pwr legs for each stepper. I would think that you'd want to have the current limited at the feed to the board to reduce the excess current, so it doesn't cause uneccessary heat. Am I way off base here ? or has anyone else thought along these lines ?
Then again it could just be a case of extreme dislexia, and that's how I should have had them configured to begin with..... duh...
thoughts, suggestions ?
thanks guys,
Arthur
