587,033 active members*
3,833 visitors online*
Page 1 of 3 123
Results 1 to 20 of 50
    Apr 2009
    8
    Misubishi Meldas Lost parameters
    Hello
    my first post here
    I have a Hartford HV45s VMC with a mitsubihi Medas controller that has lost its parmeters. How do i reload them? I have the factory settings. I want to finish my airplane engine
    Peter
    Oct 2005
    672
    Procedure varies with which Meldas control you have. M0, M2, M3, M520? I can help with the M3 if that's what you have.
    4826
    It's a conspiracy, I tell ya! Same thing happened to me recently.....must be the end of life for a lot of lithium batteries out there Mine went for 12 years though. Had only 0.4volts left when it quit, compared to 3.6v when new. I made up a new battery pack and hung it outside the 'black box' where I can get at it for the occassional probe with a multimeter henceforth
    You'd have to wonder at the engineering for these things, when there is no circuit built to monitor the battery condition. Its about as dumb as building a car with no gas gauge.
    Mine was a Meldas 50. There is more to it than just loading the parameters back in. The control needs to be reinitialized, then formatted, changed to English, then serial port settings put back in, the PLC reloaded and the parameters and tool offsets (if you saved them) reloaded. A call to Mits support is well worth while. The guys in the North American contact office are a sharp bunch.
    Apr 2009
    8
    My control is a Medas 320.
    ]Procedure varies with which Meldas control you have. M0, M2, M3, M520? I can help with the M3 if that's what you have.[/QUOTE]
    My control is a Meldas 320. The machine powers up when i hit the power button on the controller but nothing lights up, no screen no servo lights. The controllers in the controll cabinet come up with some codes ansd lights.
    I guess i need to plug into the RS232 port to set it up and load parameters.
    BTW I found the Factory supported sevice techs but its gonna be expensive I think
    Thanks Peter
    24223
    If you get nothing on the screen, it sounds like more than parameters?
    Al.
    4826
    Peter,
    Those alarm codes may help pinpoint the exact problem. But, the list of alarms in the manual seems like it might be abbreviated (it was in my case), and you'd have to phone in to find out the interpretation.
    Oct 2005
    672
    Sounds like the battery got low. Power but no screen is typically the result. Going through this will power up the machine and make it function, but you'll still have to address the dead battery so it can all be lost when you power off again for any extended period.
    Here's what to do:
    Initialize the MC-161(9) card
    - In the back cabinet, find the MC-161(9) card on the control.
    - Locate the DIP switches along the edge of the MC-161(9) card.
    - Starting from the topmost switch, flip the first, third, and fifth switches on.
    - Turn on the main disconnect, then turn on the control for 30 seconds. The screen will still be blank.
    - Power everything off and set all the DIP switches back to the left/off positions,
    - Power up the control again.
    - You should now have a display.
    Format the memory and load the canned cycles
    - Go to the ALARM/DIAG screen and press the soft key for PLC-I/F.
    - At the bottom of the screen in the first three fields, enter 1001 in the DEVICE field, leave DATA empty, and M in MODE and press input.
    - Go to the TOOL/PARAM screen, and press the soft key for BASE2
    - Change fix_P to have a value of 1.
    - Go to PROGRAM/ IN/OUT screen.
    - Press the soft key IN/OUT at the bottom of the screen.
    - Press the soft key for ERASE.
    - In the DATA field, type FORMAT and press input.
    - Press the soft key INPUT.
    - In the #( ) field, enter 4 and press the input key to reload the fixed cycles.
    Set I/O parameters to transfer machine parameter file
    - Go to TOOL/PARAM screen
    - Use NEXT soft key twice to show I/O PARAM and press the soft key for it.
    - On the first screen, we only care about the first three for DATA IN, DATA OUT, and NC RUNNING. Set them all the same for now. Set DEVICE to 0. Set PORT to 0 or 1. This depends on how the machine builder set things up. If you're not sure, set PORT to 0 and plug your RS-232 cable directly into the port on the MC-161(9) card.
    - Press the soft key NEXT to get to page 2/5.
    - There are three fields to enter data. The first is for the DEVICE you are communicating with (in case you want to use different settings for simple transfer and DNC modes), the second field is the parameter #, and the last is the value of the parameter.
    - I set my machines with the following:
    - These settings will run 9600 baud, 7 data bits, even parity, and 2 stop bits.
    Code:
    DEVICE NAME XON
    BAUD RATE 1
    STOP BIT 3
    PARITY EFF 0
    EVEN PARITY 0
    CR. LENGTH 0
    TERM TYPE 0
    TERM CODE1 0
    TERM CODE2 0
    REWIND CODE 0
    HANDSHAKE 3
    DC CODE PARITY 1
    Transfer the parameter file to the machine
    - Get your PC ready to transfer.
    - Go to PROGRAM/IN/OUT and press the soft key IN/OUT.
    - Press the soft key for INPUT.
    - In the # ( ) field, enter 3 and then cursor over to the DATA field. Leave it blank and press the input key. If the PC is ready and the RS-232 cable is correctly wired, the control will be waiting for data.
    - Go back to the PC and initiate the transfer.
    - When all the data is in, press RESET.
    - Power off the control, then power off the main disconnect.
    - Wait about 5 seconds and power the machine back up.
    You may still need to load the tool change macro also. Some machines also require setting specific parameters for the current tool in the spindle, tool magazine position, etc. Those parameters will only come from the machine builder.
    Jan 2008
    199
    If it's a M320 control then the CPU card is a MC111 PCB. If it's an M320V control then it will have a MC161 or MC161-1 PCB for the CPU. If it's an M3A control then it would have a MC161-9 PCB I believe. Then follow the procedure below. If it's a MC111, you only need to flip dip 1 & 3.
    Chippy
    Apr 2009
    8
    Followed the procedure
    Hello
    I followed the procedure. I have the same outcome, No screen no NC light. I tried 3 times with the third having the machine powered up to put charge into the battery for 3 hours. Its a MC161-1 card the System is a M320V
    Thanks Peter
    Oct 2005
    672
    I've given you all I know. I can only suggest contacting Mitsubishi from here. Unless, the battery is so dead that it will not tolerate even the brief power off during the initializing procedure.
    Apr 2009
    8
    Thanks for the help
    Ill get Mitsubishi to sort it out
    Thanks for your help
    Btw im building a 5 cylinder full size radial aircraft engine form scratch clean sheet.
    Peter
    Oct 2005
    672
    That I would love to see. Pictures are especially appreciated on such projects.
    Jan 2008
    199
    Peter,
    If you haven't fixed this yet, try this combination on the dip switches.
    1,2,3 which is a card recognition
    1,3 which is a ram clear
    1,3,5 which is a deeper ram clear.
    Then turn dip 1,5 back off leaving dip 3 on. Which does not allow parameters to be loaded from the EEPROM. You will see Japanese in the language. See if this chnages anything.
    Some times there is garbage in the EEPROM that mess up the memory.
    Each step above needs to be done sequentially. Chnage the switches, then power on for 10 seconds. Usually LED's change condition on the 2nd and 3rd step above.
    Good Luck
    Chippy
    Apr 2006
    3206
    I just replaced that 3.6V battery, (which was down to .7V!)but now the 640T boots into Windows95, then goes to the full yellow splash screen with the CNC PC Fusion graphics, and that's it. Can't go anywhere from there.
    Do I need to plug in a full keyboard to access the bios setup? Since I don't really have good documentation, I'm not real excited about random dip switch manipulations..
    Now I'm trying to get Mazak service....and they don't seem to be returning calls....What's a kid to do??
    Apr 2006
    3206
    Update...
    Just got off the phone with Curt at Mazak, who sent me to Ralph, who is going to help me out with re-initializing the controller, who then sent me to applications....where I had to leave a voicemail.
    ....to be continued
    24223
    I found it much more informative and helpfull to contact Mitsubishi (MEAU) Tech support, Chicago .
    They will fax you procedures etc.
    Al.
    Dec 2007
    300
    Smile
    When you call MEAU make sure they create a case number. That way you don't have to explain your problem the next time you call on this issue. Most importantly if Mits techs recommend a part and it does not fix your problem they will take it back. Otherwise your usually out of luck on electrical items.
    Mar 2004
    47
    I have been thru this problem recently with a M0. It looks as if your battery is dead. MIts at 847-478-2500 gave me a restart procedure that started with push 2 soft keys at once. I entered the parameters with the key pad. I am looking for the sensor that does the spindle orient on this style machine.
    Robert Setree 502-452-9851
    Apr 2009
    8
    Up and runnung
    Hello all
    It turned out that I lost the options as well as the parameters. I got Mitsubishi to come and set it up again
    All done in 3 hours.
    Thank you all for your help
    Ill be posting pics of my radial aircraft engine here when its running (soon I hope)
    Peter
    Dec 2006
    29
    Meldas 320 parameters
    Hi guys
    I have a 1989 goodway lathe with meldas 320 control. I have lost allthe parameters and I don't have any back up for this.I tried Taiwan and California for backup unsucessfully. can anyone help me on this Please.
Page 1 of 3 123
  1. Need Mitsubishi Meldas 320' parameters for Cincom L16
    By Nickon59 in forum Mitsubishi controls
    Last Post: 10-03-2023, 05:06 PM
  2. OKK MCV-300 , Meldas 84, parameters
    By Nymisis in forum OKK
    Last Post: 10-03-2023, 05:01 PM
  3. Meldas Leadwell MCV-550 lost parameters
    By fresko in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-12-2019, 05:19 AM
  4. Mighty Viper VT-8 Mitsubishi Meldas 64L Control Lost Parameters
    By 2kjettaguy in forum Mitsubishi controls
    Last Post: 04-25-2013, 10:38 PM
  5. Meldas 625m control parameters
    By otanica in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-29-2011, 02:35 AM
