i make driver with L297 and L298 (picture attached).
i test the board with mach3, when i enable the driver:
(measured voltage maybe a little bit inaccurate since i use cheap VOM meter)
voltage at output 1 = 12.5v
voltage at output 2 = 10.6v
voltage at output 3 = 12.9v
voltage at output 4 = 10.3v
and the motor producing noisy sound.
is it normal to have all output at high voltage?
then i start to step forward the motor, it spin (noisy sound gone).
when i stop sometimes noisy sound back again (output voltage relative the same but on different position), but sometimes motor producing less noisy and out put voltage (sometime on different position) :
voltage at output 2 = 11.6v
voltage at output 3 = 1.3v
voltage at output 4 = 2.1v
I put 74hc14n on l297 input stage, direct connection from l297 output to l298 input.
where i do wrong?
