586,822 active members*
3,266 visitors online*
    Mar 2009
    32
    Laser cutting eva foam
    Would it be possible to laser cut a depth in eva foam without too much heat being generated?
    So if you had a 20mm thick peice of foam, you could cut squares out to a depth of 16mm, (say 60x25mm) or would you have to really cut out that shape from a 16mm peice of foam.
    Would lasering a area 60x25mm be a problem?
    Cheers
    Dec 2008
    1258
    James,
    You will have a lot of trouble trying to regulate the cut depth due to non uniformity in the material. It will need to be cut through for best results.
    EVA foam is much more difficult to cut as the thickness increases, 20mm will require around 100W for clean single pass cutting. It can be cut with much less power but the edges/corners will melt due to the slower speeds required.
    This may not be a problem depending on the application, in fact the results may be desirable (rounded edges occur on the top surface only).
    The size is no problem.
    Zax.
    Mar 2009
    32
    Thanks Zak,
    Kinda makes life a bit difficult.
    I've got wall ventilation for it today, so I should get set up this afternoon.
    I've got some 10mm eva so I'll give that a bash.
    (I also got me a abc fire extinguisher).
    Dec 2012
    19
  1. Laser cutting craft foam, have you done it?
    By rpage in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-20-2015, 11:31 AM
  2. Laser recommendation for cutting foam
    By jevans111 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-16-2013, 09:29 PM
  3. Cutting XPS foam with cheap laser?
    By aleksazr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-14-2010, 03:31 PM
  4. Laser Cutting Foam
    By James80 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-17-2009, 02:21 PM
