586,388 active members*
3,412 visitors online*
    Mar 2009
    Scaling problem
    I was trying to have the rotary axi installed for the sherline machine.
    I was able to get all the 4 axis running, but the problem is that the x y z axis are not having the right scaling. ie. G-code of g0x10(which is letting it move in x direction by 10mm), but the actual movement is rather like 7 or 8mm.
    What am i supposed to do to have the right scaling?
    Feb 2007
    514
    You need to set the scale to the correct value for your machine or figure out if it is loosing steps.
    http://www.linuxcnc.org/docview/html...nfig.html#sub:[AXIS]-Section
    John
  1. G51 Scaling: how to?
    By Donkey Hotey in forum Haas Mills
    Last Post: 06-07-2010, 04:08 AM
  2. scaling
    By mike hide in forum SheetCam
    Last Post: 11-11-2008, 03:27 AM
  3. scaling
    By reedmiles in forum Haas Mills
    Last Post: 02-28-2008, 04:11 PM
  4. scaling?
    By BiggerHammer in forum Hobby Discussion
    Last Post: 02-20-2008, 04:40 PM
  5. Scaling?
    By Ken_Shea in forum OneCNC
    Last Post: 05-13-2003, 05:58 PM
