586,882 active members*
3,797 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > encoder count recomendation
Results 1 to 11 of 11
    Dec 2008
    34
    hi just wondering what brand,type, and line count you recomend for use with the viper 200. i have motors rated at 4500 rpm with 2-1 belts to a 5tpi ballscrew for x and y. the z is 1-1 on the belts with the same 5tpi ballscrew would like to be able to command to .0001 and rapid around 200ipm. i think this is possible with mach 3 and a 4x step muliplier with 1000 line encoders or would 2000 line with 8x step multiplier be better? any info would be apreciated. thanks, John
    Dec 2004
    1865
    5tpi*2:1 =10motor turns/In.*2000cts=20,000cts/in.
    20Kcpi*3.3ips(200ipm)=66k cps or 66ksteps/sec
    20ksteps/in =0.00005"/step which is half of what you are looking for so using a 500line encoder in quad will give this resolution.
    A 1000 line encoder in quad will give 0.000025/step. Which is 40k steps per inch x 3.3ips(200ipm) = 132khz
    132/8=16,500khz which is well within mach3's range of output thru the pport
    2000 in quad is double that so it would be 32khz which mach3 should run on a good computer or a smooth stepper or other pulse generator.
    :withstupiI had to take my shoes off to do the math, so maybe somebody can check it for me.:withstupi
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Dec 2008
    34
    Talking
    thanks totallyrc the math loks good to me. i was more wondering what resolution i would need for a good error following range "window".this a 9 x 49 mill with ballscrews so there shouldn't be excessive inertia. and would i want the same on the z or half the count?:wave:
    Dec 2004
    1865
    On my machine I use 500 in quad =2000 oer rev with a 5tpi screw and I can command .0001 jog moves. But since there is .003 backlash in the screw currently, I am content. I have a 500 step following error, which I am going to probably decrease as I get a better handle on the servo tuning
    I would use double the encoder count on the z to keep it to same on each axis.if you use 2000 on the X and Y use, use 2000 on the Z to keep it the same.
    Mariss of Gecko has switched all of his test equipment to the amt-102/103????? capacitive encoders that you can get from Digi-key and highly recomends them. They also offer adjustable resolution via dip switches on the encoders.
    I am currently using the renco encoders from ebay and they are working well for me at this point.
    When I order encoders for the lathe conversion soon, I will give the amt's a try.
    Dec 2008
    34
    thanks totallyrc those look like interesting encoders problem is the motors are set up with shaft couplers and self contained drc encoders model 77L-11-A13-635AH of unknown resolution and possibly single ended they also say 6vdc so i dont think they will be useable maybe al knows somthing about them?
    Feb 2007
    966
    Thats a single ended encoder and one of my customers had to add differential line drivers to drive a 10' cable reliably, but they worked ok after that.
    You can't a beat US digital differential encoder though.
    Dec 2008
    34
    thanks larken. if those are single ended do you think i can use the ones already installed or would that 6vdc not work with the viper ? i'll check the number of wires and any other info in a few days if i can the mill is at my brotherinlaws at the end of a really really muddy section line driveway and i don't have a 4wheel drive maybe you've seen north dakota in the news lately it's not a pretty sight. What model from us digital do you use they have quite a few models .thanks again, John
    Feb 2007
    966
    6Volts ?? Its probably 6 volts max, but will run on 5 volts.
    BTW, Don't be wiring up those vipers while your standing in 2 feet of water.
    Dec 2008
    34
    Smile
    thanks for the reply maybe i'll have to try them there are 10 wire connection screws on them only 5 labeled and only five currently used though. ch A, ch B, ch Z, v+, grd. any way to tell what resolution they are? we are in western nd northwest of bismark 35 miles no river flooding here just 6-10' snow banks yet just got done with another blizzard i think i heard there is another planned for thursday or friday though. 2 more inches to be record snowfall for a winter! it's getting old. :tired:
    Feb 2007
    966
    Whats the model and part# of the encoder ? It woulod be best to run it in differential mode.
    Dec 2008
    34
    hi the model on the encoders for the x & y are : DRC 77L-11-A13-635AH the AH lettters are only on the y. the z has what looks identical but relabeled by tri-onics, the original converters of the mill, i didn't take any numbers off of it though.any help would be appreciated. thanks, John(group)
  1. Servo Encoder Count in Mach3
    By thosj in forum Automation Technology Products
    Last Post: 05-21-2010, 09:44 AM
  2. Bridgeport Series 1 R2E3 Encoder Count
    By krz2_2000 in forum CNC Machine Related Electronics
    Last Post: 05-20-2009, 02:24 PM
  3. 320 encoder count max ?
    By LUCKY13 in forum Gecko Drives
    Last Post: 04-04-2009, 11:11 AM
  4. Encoder Count
    By Billiam in forum Servo Motors / Drives
    Last Post: 03-16-2009, 03:20 PM
  5. VFD recomendation
    By Danno in forum Phase Converters
    Last Post: 11-17-2008, 06:07 PM
