586,497 active members*
3,116 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko power supply 2/3" current rating?
    Jun 2003
    1365
    I am revamping my mills controller box, actually building a new one and I just saw that geckos only use 2/3 the rated power. Does this mean that I can take my 3 4.7A motors and run them off a 10a power supply? Do they always draw less or this much or will they go over? 4.7 * 3 = 14.1A, but 2/3 of that is: 9.4A
    Would I be risking it if I built a power supply with 2 10A transformers in series or should I use 4? I have 4 available but would rather not use them all if I don't have to.
    Jon
    Jun 2003
    1365
    No one can help?
    I took a look through the manual and it seems pretty rock solid. I guess Ill just try it and monitor the temp of the transformers.
    Jon
    Aug 2004
    2849
    Quote Originally Posted by JFettig
    Jon
    Okay, it's not that Geckos use less power it's that PWM is used therefore what most have observed is that with the duty cycle that is most often used / achieved only about 2/3 of the current rating for each phase is observed.
    Why would you want to put the power transformer outputs in series? You would actually want to parallel the outputs to gain the additional current rating....so 2 10amp outputs would suffice. Better to have some extra current reserve then not having enough.
    Jun 2003
    1365
    I am putting them in series to get a 67v 10a power supply, otherwize I have 4 power supplies to double the current, in a series-parallel configuration.
    Jon
    The Gecko site says motors wired bipolar parallel will never exceed 2/3 the rated current. 1/3 for bipolar series.
  1. How does a power supply work.
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-27-2011, 03:40 PM
  2. Gecko power supply
    By DEEDEE in forum Gecko Drives
    Last Post: 08-02-2005, 03:56 PM
  3. Motor calculations
    By jevs in forum CNC Machine Related Electronics
    Last Post: 03-21-2005, 08:05 PM
  4. Is this power supply rating adequate?
    By jerryrigge in forum CNC Machine Related Electronics
    Last Post: 11-25-2004, 05:06 PM
  5. current per phase for power supply?
    By FLUTE HEAD in forum CNC Machine Related Electronics
    Last Post: 07-31-2004, 06:41 PM
