586,781 active members*
3,025 visitors online*
    Mar 2009
    lantek expert use
    hello boys how are you? I am new in this forum and i need help if you know. I use lantek expert for cnc plate machine and i want to make common cut for several parts with one lead in.i have found this setting but i want also to recognize the program the already cutting sides. if you know please help me
    Apr 2010
    22
    Hello. I'm also working with Lantex Expert
    Hello there. i dontknow if i can help you but i'm working with Lantek since 2004 but is the Lite version. Hope you solved your problem but if not, then i think we can discuss it if yu want or need Take care
    Mar 2019
    agiorgos Good morning friend !
    Th version that you use in original? or cracked ?
    May 2020
    8
    Re: lantek expert use
    What machine should i install in Lantek Expert v27 so i can generate a compatible G-Code with Dragon 1 CNC from Steel Tailor?
  1. lantek expert 1
    By boomer187um in forum CamSoft Products
    Last Post: 01-13-2024, 09:26 AM
  2. i'm looking for lantek expert v 27
    By agiorgos in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 08-22-2023, 11:33 AM
  3. Lantek
    By scott24 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-22-2020, 06:55 AM
  4. Lantek Expert
    By one5 in forum Laser Control Software
    Last Post: 04-20-2013, 07:29 AM
