586,931 active members*
2,715 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Surface to Surface Filleting and Trimming
Results 1 to 7 of 7
Threaded View
    21
    MasterCam Version 9
    Have been trying to fillet the edges of the attached part and can only get it complete to the shown stage.
    Using surface/surface fillet with trim surfaces enabled, but the upper flat surface does not trim. Could not get the 2 surfaces to fillet in a single operation and had to use pick a pair and work my way around the contoured part to obtain the shown result.
    Also have been trying to surface/surface trim the 2 protruding surfaces at the part pointed end but no success there either.
    Then tried surfacing the part as drawn but I keep getting a "self intersecting" message. Followed the prompts to change color of the intersection but never see it show up on the drawing.
    Would really appreciate someone taking a look and give me some guidance as to what I am missing and doing wrong. Feel like I am close but just can't get over the hump.
    TIA,
    cem
    Attached Files Attached Files
  1. Trimming surfaces for surface milling
    By data-matique in forum Mastercam
    Last Post: 12-14-2008, 11:45 PM
  2. surface help
    By msn_jrd in forum Mastercam
    Last Post: 11-20-2008, 01:28 AM
  3. cut from surface
    By Flankman in forum Musical Instrument Design and Construction
    Last Post: 09-03-2008, 12:49 AM
  4. *.obj to surface in MX2?
    By tesart in forum Mastercam
    Last Post: 05-28-2008, 09:41 PM
  5. MDT 6 Surface Cut
    By djzepp in forum Autodesk
    Last Post: 04-11-2007, 04:56 AM
