586,966 active members*
2,953 visitors online*
Results 1 to 7 of 7
    Mar 2009
    4
    Canned Cycle - Fanuc oi
    I've never attempted a canned drilling cycle before and the big yellow book seems to be confusing me more than helping me. Can anyone give me a straight forward example of a G83 canned cycle for Fanuc control, from start to finish. I would really appreciate any help, thanks.
    Nov 2007
    188
    canned cycle
    Try the link below there are some very good post there that will help you
    http://www.cnczone.com/forums/showthread.php?t=73951
    2932
    Mill or lathe?
    Jan 2006
    4396
    Read this, it will help. G83 is the same for a Lathe or Mill. The only exception is that unless you have a Mill/Turn your only going to program X0.0 and a Z Depth for a 2 Axis Lathe.
    The Mill is a XY location and a Z Depth.
    G90 G0 X0 Y0
    G83 Z-.5 R.1 Q.1 F12.
    X0 Y0 Location
    Z-.5 in depth
    R.1 is the return point after each peck
    Q.1 is the Peck amount
    F12. is the feed rate at 12 Inches Per Minute
    Toby D.
    Schwarzwald
    www.refractotech.com
    Mar 2009
    4
    Oh yes I forget to mention that it's for a lathe. Thank you for the responses I really appreciate the help.
    Mar 2009
    4
    Oh and I also forgot to mention that I'm not using live tooling.
    Jan 2006
    4396
    That means that you will be using this format
    G0G40G99M5
    G28U0W0
    N2(DRILL)
    T202M8
    G97S700M3
    G0X0Z.1
    G83 Z-.5 R.1 Q.1 F.007
    G80
    G28U0W0
    T200M9
    M1
    X0 Location center of stock
    Z-.5 in depth
    F.007 is the feed rate at .007 Inches Per Revolution
    On a lathe you can use either G99 (Inches per Rev) or G98 (Inches Per Minute)
    Be careful when switching between IPR and IPM. The wrong designation will surely cause problems.
    Toby D.
    Schwarzwald
  1. canned cycle for lathe with fanuc control
    By JPann in forum G-Code Programing
    Last Post: 09-27-2011, 06:45 PM
  2. Fanuc Canned Cycle MACROS
    By kuyohtay in forum Fanuc
    Last Post: 05-20-2008, 09:40 PM
  3. G90 (Canned turning cycle) Fanuc 21i-TB ?
    By Jdavis733 in forum G-Code Programing
    Last Post: 01-24-2008, 03:18 AM
  4. Canned Cycle G73 Om Control Fanuc(drill)
    By marrieche in forum Fanuc
    Last Post: 03-05-2007, 11:51 PM
  5. Replies: 2
    Last Post: 01-20-2006, 08:39 PM
