Originally Posted by
Flenser
The raised lip on the nut goes toward the block. It has to seat against the inner bearing race to take up the slack.
If you snug the nut up a little over finger tight, you should be able to move the screw by hand along its axis. I placed a DTI at the end of the screw to measure the end play. I cut a shim from 0.005" brass to place between the bearings after seeing 0.003" play. I tried that shim pretty much every where else before deciding it had to be the bearings. The shim goes between the inner races, not the outer.
