586,962 active members*
2,819 visitors online*
Results 1 to 7 of 7
    Mar 2009
    48
    Cool Machining Question
    I need to machine some 1" holes on my CNC and I was just going to use a 1/2" end mill but the blue print requires .0005" TIR. Should I be able to expect to hold this tolerance just by circular interpolating the hole or should I do something else?
    21
    Unless the machine is really new, that kind of tolerance is difficult to maintain. Boring is the way I would go. The hole will be round rather than machined in quadrants. It really depends on the ways of the machine.
    I agree.....0005" is pretty close on most machines. If it were 1 part I have done, just re-running it and basically rubbing the size it, but I would boring is the way to go.
    Mike in MN
    http://www.cncbasics.com
    http://www.cncbasicsforum.com
    www.cncbasics.com
    Mar 2005
    1136
    boring is more accurate than interpolating buy to split hairs is suppose it would depend on the machine wether interpolation would hold the tolerance. btw, its better if you put a subject line that has some meaning
    Dec 2008
    30
    you could interpolate it to about .003 undersize then ream it to size... although a reamer that size would cost quite a bit
    Mar 2006
    2712
    Drill undersize and ream with a jig borerer (end cutting, no chamfer) reamer?
    Dick Z
    DZASTR
    Mar 2009
    48
    All, thanks for all the help. I guess I will plan on boring it.
  1. Al6061 machining question
    By JayH1119 in forum MetalWork Discussion
    Last Post: 05-14-2008, 01:38 AM
  2. Basic Machining Question
    By asperjack in forum MetalWork Discussion
    Last Post: 05-25-2006, 04:19 PM
  3. Question about machining aluminum
    By djmachinist in forum Benchtop Machines
    Last Post: 10-29-2005, 12:27 AM
  4. Question about machining aluminum
    By mustbenu in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2005, 02:41 AM
  5. basic machining question
    By senor J. in forum MetalWork Discussion
    Last Post: 12-08-2004, 05:48 AM
