587,048 active members*
2,939 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Body into new part within assembly
Results 1 to 5 of 5
    May 2008
    26
    Hi Guys,
    im making a cube within sw each side of the cube is a new part. (top down assembly) ive made cut through one of the panels creating a new body of the part.
    I want to be able to turn that body into a new part within my assembly without having to offset surfaces then knitting it back together is there a way to do this.
    i have just phoned the helpline and the couldn't help, it sounds like a really simple action i just cant work it out.
    ive attached a picture so you can see what i mean.
    Jan 2009
    56
    I think the Split feature is what you are looking for.
    INSERT|FEATURE|SPLIT
    TM
    Sep 2005
    1660
    I'm not sure I follow your description but, if your top part has been split into two parts you can open it at the part level, export the part into a new part then delete it in the original part file and insert the new part file back into your assembly?
    JerryFlyGuy
    The more I know... the more I realize I don't
    May 2008
    26
    SPLIT! of course!!! thanks for your help!
    May 2008
    26
    Quote Originally Posted by JerryFlyGuy View Post
    Thanks for your reply, i had thought of this but i didn't want to have to re position the parts after bringing them back into the assembly.
  1. RFQ Stainless Steel body part
    By cdarnell in forum Employment Opportunity
    Last Post: 07-10-2015, 04:58 PM
  2. Convert part w/ bodies to assembly?
    By Rich05 in forum Solidworks
    Last Post: 02-03-2009, 05:35 PM
  3. A light-weight table/bearing assembly with a low part count.
    By greybeard in forum Linear and Rotary Motion
    Last Post: 11-10-2005, 12:16 AM
