i'm having a problem with my machine. the last time that i had it running it would jog around with no problem. today i went and turned it on and for whatever reason the directions when i'm running it in jog mode on mach 3 are switched around. back and forth on the x-axis are fine, but the y-axis moves right whether you push right or left, and the z-axis isn't working at all.
All my cable connections seem to be tight and just the way they were before. where should i start looking to fix this?
