586,265 active members*
3,727 visitors online*
    Oct 2007
    56
    Serial pulse coder
    I experience 350 alarms with serial pulse coders freq. 350 indicates phase problems
    Any tips on repairing or aligning the units or a reasonable repair service???
    Sep 2007
    371
    Whart is the model of your encoder??
    Oct 2007
    56
    A860-0346-T141. particularly. Lots of failures...Shaft Bearing is almost always bad. Bearing can be changed. But prone to 350 alarms?????? I replace the unit. Fanuc does not repair them. $1100.00 throw away
    Aprox 40 Okuma Howa Lathes turning plastic with no coolant.
    Sep 2007
    371
    Alligning that unit is not easy, you'll need as minimum an oscilloscope with the capability to freeze the image of the signal to allign them, they must be 90º one from the other (A,B) there are also more sophisticated equipment like the Heidenhain to do this but it costs about 10k. We have been repairing them at our lab. 50-50 success, try contact tenesee industrial electronics, maybe they can repair it in USA.
    Greg.
  1. Fanuc pulse coder pinout?
    By Jonne in forum Servo Motors / Drives
    Last Post: 02-02-2013, 03:49 AM
  2. Pulse coder alarm
    By stevo1 in forum Fanuc
    Last Post: 08-18-2010, 07:18 PM
  3. Adjusting Servo with pulse coder
    By Dustin L in forum Servo Motors / Drives
    Last Post: 12-17-2008, 08:13 PM
  4. Unfit Pulse Of Pulse Coder Alarm
    By Crashmaster in forum DNC Problems and Solutions
    Last Post: 04-23-2007, 03:55 PM
  5. Fanuc Pulse Coder
    By Derek.C in forum Fanuc
    Last Post: 01-04-2007, 03:24 AM
