586,501 active members*
3,263 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Question reguarding Old vs. New Taig mill
    Sep 2007
    48
    I've been running the first gen taig as a CNC mill for a while now. I've come to the point where i'm locking down on making the machine more accurate. I've noticed the new style taig comes with preloadable nuts on the X and Y axis, and the Z axis uses box ways as opposed to the dovetail ways on my machine.
    I'm trying to figure out if the preloadable nuts on the new X and Y axis would work with my older taig mill? From the diagrams on taig's website it doesn't look like anything relevant to the leadscrews has changed between the two versions of the mill, but I'd like to be sure before purchasing the preloaded nuts. Also it looks like the Z axis has been extended, is this true? Thanks!
    I've toyed around with the idea of converting the machine to servos and ball screws, but at $600 an axis in the end it's just not worth doing to this little guy.
    Oct 2004
    168
    The adjustable nuts should retrofit fine, I've done it on one of mine.
    The new z-axis has a tiny bit more travel.
    Quote Originally Posted by Anokiernan View Post
    Nick Carter
    Largest resource on the web about Taig lathes and mills
    www.cartertools.com
    Sep 2007
    48
    Do you think the extra travel is worth the hassle of converting over to the newer way? I've learned to work around the limited Z axis most of the time, but I'm sure later down the road it'll bite me when I need it the most.
    Oct 2004
    168
    It's a hard call. I got by for years with the old z-axis, I really only converted so I could support the new one. The new one is more rigid, and likely more precise. I can't really remember how much more travel you get but I think it's on the order of half an inch at most?
    Nick Carter
    www.cartertools.com
    Sep 2007
    48
    Thanks! Just the info I was looking for
  1. Taig 3 Jaw Chuck on Taig Mill?
    By jim_stoll in forum Taig Mills / Lathes
    Last Post: 09-19-2017, 04:38 PM
  2. Coming Down to the Taig Micro Mill or Grizzly Mini Mill.
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 01-23-2009, 06:14 AM
  3. Taig X Axis Question
    By gunlocators in forum Taig Mills / Lathes
    Last Post: 09-02-2008, 04:53 AM
  4. Taig way Lube...Question
    Last Post: 07-21-2008, 02:32 AM
  5. taig question
    By dfurlano in forum Taig Mills / Lathes
    Last Post: 05-10-2007, 08:13 PM
