586,797 active members*
3,540 visitors online*
Page 1 of 4 123
Results 1 to 20 of 66
    May 2007
    86
    z axis sticking / missing steps
    :violin:
    I have a taig CNC mill with Xylotex controller & I am running it from EMC.
    I was using my mill a few days ago with no problems what soever. I was milling wood (pine). Then all of the sudden the z axis stuck. No reason that I could see. The rapid for the z was only set at like 12IPM. So I did some research.
    I found people suggesting that it could be a loose Gib. So, I took the head assembly off and checked my Gib. Sure enough it was a little loose. I re-installed and re-adjusted it till it would move freely yet had no side to side movement. Get the mill back together completely and try the z out, it was no better at all. Still sticking even at like 8 ipm.
    So I did some more research and found people suggesting that the pieces that hold the z axis assembly on the z slide could be loose. I checked mine and it was indeed a little loose. So I tightened it up (only by hand). The z axis assembly was able to slide up and down by hand without too much difficulty. So I put the motor back on and got it all set back up. Tried it out at 12 ipm still sticking, not as bad though. Lowered the speed down to 11 ipm and it seemed to be ok. So I set up a part and started to mill it. The z worked without sticking for like 1 up movement & then skipped some steps.
    This leaves me unsure of what to try next. Which is why I am posting for HELP! :drowning:
    Oh yeah, the sticking (missing steps) problem seems to only be with upward travel, down is fine.
    Frank
    Nov 2008
    113
    Are the ways oiled? If not order some Vactra 2 (http://www.mcmaster.com/ has reasonable price per/gallon -- which will last forever -- and they ship quickly).
    Also check your motor accelerations, if you try to accel too quickly the motor will stall.
    May 2007
    86
    Yes the ways are oiled. And as far as the acceleration goes, it was just working fine. And it usually doesn't get stuck immediately, it will be moving fine and then stick.
    Thanks for the reply & suggestions. I might try turning the accel down tonight just for kicks to see if it helps.
    -Frank
    Mar 2008
    3655
    Hi Frank!
    You are cutting wood on a metal-cutting machine. Have you checked to see if sawdust adhering to greased parts is clogging things up?
    CR.
    May 2007
    86
    I've taken the whole z axis assembly off several times now & I have cleaned everything from the lead screw to the way. I've been cutting wood without issue, till now.
    That was my exact first thought when it started sticking. I figured that it just needed a little cleaning. But after cleaning, oiling, adjusting I am still having the problem.
    Frank
    Mar 2008
    3655
    So are you saying that the Z axis is MECHANICALLY sticking? Can't move by hand with power off? Or is it that the motor stops turning or stalls?
    CR.
    May 2007
    86
    Well for one thing, it will stick and then start moving again. Almost like it just pauses for a moment losing steps. Like last night when I started running that part it did some milling and then was supposed to go from like z-.125 to z.05 but it ended up going more like to z-.05 & showing z.05....and then it proceeded to mill through my block because it hadn't traveled above the part like it was supposed to.
    When I have taken it apart I have not found that it sticks mechanically. So now I am kind of thinking that it may not be something mechanical. The oddest thing is that it was just working fine.
    Does that answer your question?
    thanks
    May 2007
    86
    I have another identical stepper, from my fourth axis that isn't currently setup, that I can swap with the z axis stepper to make sure that that is not the problem.
    Mar 2008
    3655
    That's good to try. If that doesn't help, you might also want to swap the Z driver with another driver position and run a test program.
    CR.
    May 2007
    86
    Yeah, that is a good idea, I didn't think about swapping which axis the motor was plugged into. Thanks
    Mar 2008
    3655
    If your Xylotex IS blown--And you call IMMEDIATELY--You MIGHT still get one of the $225 Overstock Special G540s:
    714-832-8874
    CR.
    May 2007
    86
    I have had my xylotex go bad before, twice. Each time though everything quit working.
    And xylotex did fix it.
    What would be the benefits of the Gecko?
    May 2007
    86
    Would I have to also get a new power supply?
    Mar 2008
    3655
    Not necessarily. G540 will run motors better than Xylotex even with 24V PSU. You COULD upgrade PSU at any time though for even more performance.
    CR.
    May 2007
    86
    sounds good. I'm going to have my wife call (I'm at work) and see if they have any left.
    May 2007
    86
    I'm in luck. They had a few (7) left. So a 540 is on the way.
    A couple of questions about the G540:
    Where's a good place to get the DB9 pigtails?
    Will this drive fit inside my Xylotex box without mod?
    Will I have to change the way my EMC file is set up?
    Mar 2008
    3655
    Congratulations. You will be amazed by the difference!
    Quote Originally Posted by 725franky View Post
    They come with it. You WILL need about eight 3/4 inch 4-40 screws though.
    It should, it may be smaller than a Xylotex. 2 3/8" high x 6" wide x 1" deep. You need to cut a rectangular hole, but there is a template with it.
    I don't know. I don't run EMC2.
    CR.
    Mar 2008
    3655
    Oh, what size and amps are your Xylotex motors?
    CR.
    May 2007
    86
    269 oz steppers
    don't know the amperage...i'll have to check when I get home.
    May 2007
    86
    Just checked Xylotex website:
    2.8A
    http://www.xylotex.com/StepperMotor.htm
Page 1 of 4 123
  1. Motor missing steps then reversing ???
    By SScnc in forum Benchtop Machines
    Last Post: 09-27-2008, 09:11 AM
  2. Missing steps?
    By beezerlm in forum Machines running Mach Software
    Last Post: 05-13-2008, 03:59 AM
  3. Servos jumpy n missing steps....
    By bigal in forum Gecko Drives
    Last Post: 09-29-2006, 09:52 PM
  4. Missing steps ?
    By DavyD in forum Machines running Mach Software
    Last Post: 05-10-2006, 08:06 AM
  5. Missing Steps with Laptop
    By alanc2 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-08-2004, 08:39 PM
